Question:
I have a strobe pin in BCD Parallel Interface that I do not know what to do about it. I read about connecting the strobe line to one of the Arduino inputs associated with an interrupt. I am not sure if I am on the right track and as a start, I would like to learn how to create a strobe in Arduino.
Context of my Project:
Enter an input frequency (from 0.3 to 18GHz) & set the Frequency Modulation mode in my PC where this data is sent to Arduino Mega ADK board and subsequently to the Frequency Synthesizer via a 50 pin connector, to control its output frequency and mode.
Setup:
Info from the Frequency Synthesizer's Data Sheet:
Progress thus far:
I have written a code to map the outputs to the respective pins as seen below. The user configurable parameters (Input Frequency & FM mode) are currently hardcoded & stored in arrays for easy retrieval to the BCD Parallel Interface. So for example, I have set the input frequency to be a random number at 17834533324Hz in this case.
//Pin Assignment
pinMode(0, OUTPUT);
pinMode(1, OUTPUT);
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
pinMode(12, OUTPUT);
pinMode(13, OUTPUT);
pinMode(14, OUTPUT);
pinMode(15, OUTPUT);
pinMode(16, OUTPUT);
pinMode(17, OUTPUT);
pinMode(18, OUTPUT);
pinMode(19, OUTPUT);
pinMode(20, OUTPUT);
pinMode(21, OUTPUT);
pinMode(22, OUTPUT);
pinMode(23, OUTPUT);
pinMode(24, OUTPUT);
pinMode(25, OUTPUT);
pinMode(26, OUTPUT);
pinMode(27, OUTPUT);
pinMode(28, OUTPUT);
pinMode(29, OUTPUT);
pinMode(30, OUTPUT);
pinMode(31, OUTPUT);
pinMode(32, OUTPUT);
pinMode(33, OUTPUT);
pinMode(34, OUTPUT);
pinMode(35, OUTPUT);
pinMode(36, OUTPUT);
pinMode(37, OUTPUT);
pinMode(38, OUTPUT);
pinMode(39, OUTPUT);
pinMode(40, OUTPUT);
pinMode(41, OUTPUT);
pinMode(42, OUTPUT);
pinMode(43, OUTPUT);
pinMode(44, OUTPUT);
pinMode(45, OUTPUT);
pinMode(46, OUTPUT);
pinMode(47, OUTPUT);
pinMode(48, OUTPUT);
pinMode(49, OUTPUT);
pinMode(50, OUTPUT);
pinMode(51, OUTPUT);
pinMode(52, OUTPUT);
pinMode(53, OUTPUT);
//Initialisation
int freq[11] = {};
int fm_mode[4] = {};
int freq[] = { 1,7,8,3,4,5,3,3,3,2,4 }; //Input frequency (from 0.3 to 18GHz)
int fm_mode[] = { 0,0,0,0 }; //Frequency mode
//Control FM Modulator
digitalWrite(6, fm_mode[0] &1);
digitalWrite(31, fm_mode[1] &1);
digitalWrite(7, fm_mode[2] &1);
digitalWrite(32, fm_mode[3] &1);
//10GHz
int i_10GHz = 0;
digitalWrite(25, freq[i_10GHz]/2 &1);
digitalWrite(30, freq[i_10GHz]/1 &1);
//1GHz
int i_1GHz = 1;
digitalWrite(37, freq[i_1GHz]/8 &1);
digitalWrite(38, freq[i_1GHz]/4 &1);
digitalWrite(24, freq[i_1GHz]/2 &1);
digitalWrite(13, freq[i_1GHz]/1 &1);
//100MHz
int i_100MHz = 2;
digitalWrite(15, freq[i_100MHz]/8 &1);
digitalWrite(16, freq[i_100MHz]/4 &1);
digitalWrite(17, freq[i_100MHz]/2 &1);
digitalWrite(45, freq[i_100MHz]/1 &1);
//10MHz
int i_10MHz = 3;
digitalWrite(47, freq[i_10MHz]/8 &1);
digitalWrite(21, freq[i_10MHz]/4 &1);
digitalWrite(20, freq[i_10MHz]/2 &1);
digitalWrite(46, freq[i_10MHz]/1 &1);
//1MHz
int i_1MHz = 4;
digitalWrite(42, freq[i_1MHz]/8 &1);
digitalWrite(41, freq[i_1MHz]/4 &1);
digitalWrite(39, freq[i_1MHz]/2 &1);
digitalWrite(40, freq[i_1MHz]/1 &1);
//100kHz
int i_100kHz = 5;
digitalWrite(9, freq[i_100kHz]/8 &1);
digitalWrite(8, freq[i_100kHz]/4 &1);
digitalWrite(33, freq[i_100kHz]/2 &1);
digitalWrite(34, freq[i_100kHz]/1 &1);
//10kHz
int i_10kHz = 6;
digitalWrite(5, freq[i_10kHz]/8 &1);
digitalWrite(4, freq[i_10kHz]/4 &1);
digitalWrite(2, freq[i_10kHz]/2 &1);
digitalWrite(3, freq[i_10kHz]/1 &1);
//1kHz
int i_1kHz = 7;
digitalWrite(29, freq[i_1kHz]/8 &1);
digitalWrite(28, freq[i_1kHz]/4 &1);
digitalWrite(26, freq[i_1kHz]/2 &1);
digitalWrite(27, freq[i_1kHz]/1 &1);
//100Hz
int i_100Hz = 8;
digitalWrite(49, freq[i_100Hz]/8 &1);
digitalWrite(22, freq[i_100Hz]/4 &1);
digitalWrite(48, freq[i_100Hz]/2 &1);
digitalWrite(23, freq[i_100Hz]/1 &1);
//10Hz
int i_10Hz = 9;
digitalWrite(18, freq[i_10Hz]/8 &1);
digitalWrite(43, freq[i_10Hz]/4 &1);
digitalWrite(44, freq[i_10Hz]/2 &1);
digitalWrite(19, freq[i_10Hz]/1 &1);
//1Hz
int i_1Hz = 10;
digitalWrite(10, freq[i_1Hz]/8 &1);
digitalWrite(35, freq[i_1Hz]/4 &1);
digitalWrite(11, freq[i_1Hz]/2 &1);
digitalWrite(36, freq[i_1Hz]/1 &1);
Please feel free to comment, I would appreciate any inputs. Thank you.
