Can anyone please recommend a good sensor for me, to sence when a big tipper truck (i.e. rough terrain) reaches a speed of say 40km/hour, or 50km/hour?
I simply need to activate a relay once the truck reached the desired speed and this can be done with an UNO.
But I am unsure of which sensor(s) to get? Some research suggests I need an accelerometer + gyrometer thought I dont know which ones would work in this kind of environment?
I don't have access to the truck, so implementing a sensor on a wheel or even drive shaft may be very tricky. The person who's going to install the unit doesn't know Arduino, or programming, so I don't know how he'll be able to "calibrate" the microcontroller according to the diamater of the shaft or wheel.
The person who wants this, want to be able to use it on different vehicles, the the tire / wheel size may differ.
It should be as self-contained as possible, i.e. hook the device upto the battery, connect the water pump to the relay terminals and switch it on.
The idea is, as soon as the vehicle reaches 40km/h, the water pump should kick in.
