Would like to store one string of around 100 bytes, every 4 seconds and would like to store around 150,000 of such strings.
The data should be retained even after power off.
Once the 150,000 strings are written, the next incoming string should be stored and the 150,000th string should be knocked off from memory.
I've read about EEPROM modules and SD card modules which should store 15 MB of data but they come with limitations of 10,000 write cycles. If I enter one string of 100 bytes every 4 seconds, I would exhaust the 10,000 write cycles in half a day!
So what to use instead of above options or am I interpreting the 10,000 write cycles limit in a wrong manner ?
SD card will be fine. The write cycles is per address, and it's more likely 100,000. 4GB card.. will take 260 days to fill... only then do you start to overwrite each address.
The 10,000 cycles is for flash, (real) EEPROM has 100,000 cycles. If you're using a controller with simultaed EEPROM (e.g. ESP8266), it uses flash as well; but that's not applicable.
An alternative to EEPROM is FRAM; it basically has unlimited write cycles. But in both cases you need a few modules to achieve the 15MB.
I agree that a SD card is probably the correct choice.
Just write the 15mb to the SD card, and let the card take care of the rest. Modern SD cards/firmware have wear levelling built in. The firmware takes care of where physically on the card things get written to optimise the lifetime of the card. Your card will last a long time if you only write 15MB a week.
