For some reason every kit I get or tutorial I read says use a 220 ohm resistor with leds. I just bought a pack of leds(100 of them, for 1 dollar... an american dollar at that and I need to get the correct resistors.
Voltage: 3.2V - 3.6V
Reverse current (uA): <=30
Max Power Dissipation: 80mw
Max Continuous Forward Current: 30mA
for my calculations I use
source voltage of 5v
forward voltage of 3.3V
current of 25mA
this gets me close to 75ohms for my resistor....
If I use 9V as source voltage I get close to 220... should I use 9v for calculations? If so why, I thought arduino only put out 5v on the pins. Does this hold true through a shift register?
My confusion here is I don't know if I am using the wrong values for my calculation, or if my leds are just power hungry little buggers...
current of 25mA
Yes you are using the correct values.
The resisitor is value is lower then usual because your LED current and voltage drops are higher than usual. Typically the voltage drop will be under 2 volts and the curent around 10ma so a resistor will be four or five times higher than that.
Not to worry, at a penny each you got a great deal
Yes, a typical LED has a little over 3 volts across the resistor connected to a 5V pin. You have about 1.7 volts.
But that is not so unusual for very high brighness LED such as yours. I wouldn't worry about burning them out. It should only happen if the specs are wrong. And if one does you still have 99 more
Anyway, its not bad thing using a larger resistor if the brightness is sufficient so put in a larger one if you want.
