What was the most exciting sensor that you tried?
I am looking to start some new project and would like some ideas for sensors that are a bit out of ordinary?
This belongs in Bar Sport, not here.
Grumpy... ;D but true
anyway, hmm, geiger counters? MQ3 alcohol gas sensors?
Not sure what you'd class as out of the ordinary.
anal probe.
I'm sorry, couldn't resist.... :smiley:
anal probe.
That classed as a sensor?
I would use the colour sensor, there are lots of projects you could do with that:-
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1239955755
thanks Mike,
I've seen somewhere an interesting sensor, like sort of temperature sensor, but with 5 pixels, so it can give you an image of the temperature distribution. If I put it on a servo I can scan around and form an image of the environment.
But can't find where I've seen it.
Thermal mapping is rather tricky an I wouldn't expect you to be able to get that in a simple sensor. Don't mix up temperature sensors with IR imaging these are separate things. Most image sensors that work at IR only do so at near IR - that is IR that is near viable light and so don't actually show much in the way of temperature information for things below about 800oC
A forum member has done this:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1253898939
