let me try edit and explain this better in my first post.
My laptop would not charge. i took a tensor ring off my finger and positioned it around the Noise suppression ferrite core thats on the charge cord of my laptop. suddenly it began charging. it was plugged into auto accessory power outlet that was at 10.1v. A week latter The auto accessory power outlet is now at 9.8volts and laptop is still charging.
did i discover something or is there a logical explanation for this? here is a pic of my cord.
this is the 144mhz tensor field generator
it creates a Tensor Field. just because somethings not plugged into a wall socket doesn't mean its power dont exist. maybe you should do your research first. A Tensor Field Generator has a 5 mile reach. research Slim Spurling
Delta_G:
A sphere of what exactly? How did you measure it?
i dont know, some kind of sphere of Tensor Field energy. i dont know how to measure it.
Tensor Fields Copper Coil Magic - The Cubit length (also called the Sacred Cubit length) is based on the circumference of the Earth at the latitude where the Pyramids are built. The ends of a length of wire have polarity (a positive and a negative side. If wire is looped back on itself and joined together, one side of the loop has a positive energy while the other side of the loop has a negative energy. In electronics, an amplifying system is subject to electromagnetic interference (noise). In order to cancel the noise, the two input wires are twisted. This is known as Common Mode Rejection. Twisting the wire when making a Tensor Ring cancels the magnetic field and creates a unique tensor field that can be seen by some individuals.
When Slim put a right-handed twist to the folded length of wire, and closed the ends back onto each other, there was a cancellation of the electromagnetic field within the Ring. This created a non-polar column of light.
The second condition for the creation of a working Tensor Ring is the length of the wire. Many people have heard of the Cubit which is a unit of measure from megalithic structures around the globe. The particular Cubit length for the Spurling Rings comes from the Great Pyramid of Giza.
Doug Benjamin, who found and interpreted a lost symbol from within the King’s Chamber, discovered four different Cubit lengths within this symbol. Doug utilized two sets of these Cubit lengths to create “Sacred Space” by effectively neutralizing harmful geomagnetic lines.
Slim began using this set of cubits for Geopathic stress remediation in GDV Imaging of a Tensor Ring and magnet creating a Meissner Effect GDV Imaging of a magnet the Denver area in the 1980’s. Rods of specific Cubit lengths were driven into the ground to neutralize the harmful effects of the Hartman Grid Lines. - See more at: The Amazing "Tensor Ring": Pineal Gland Activator and Much More - Humans Be Free
I prefer the version with a flexible logarithmic casing of pearlated amulite. I find it really reduces side fumbling and polar android regeneration.
Just because you, or someone else, put some words on a picture does not mean anything those words say is remotely true.
All of those claims are total nonsense, either in concept, or truth.
I am not too sure if you are serious here. If you are serious then this is the wrong forum for you. You will only get laughed at for being so silly. This sort of thing is just bullshit. I did do a little research to find out what you were referring to and found nothing but clap trap. Basically incoherent rubbish with a few sudo science terms thrown in to make it sound good to some one who knows nothing. However if you do know what these terms mean then it is truly laughable. Most of the claims contradict themselves.
Grumpy_Mike:
Where's your data ? In science, it's all about the data. Words are worthless. If you have data , present it,
along with your equipment list and test procedures. If you have no data, talk is cheap. The photo proves
nothing, the links prove nothing. No data, no science. That's the way it is in the real world. Have you or anyone else published any white papers on the subject ? If so, post a link.
TrailerTrash:
i took a tensor ring and positioned it around the ferrite interference suppressor thats on the charge cord of my laptop. suddenly it began charging even if the voltage supply went lower than 12v.
You didn't say but when the charger started charging the lap top was it connected to a source of "conventional power"? If it were not then there is a simple explanation of what you saw.
