What would be the way of making this code shorter for Arduino C?
  pinMode(0, INPUT_PULLUP);
  pinMode(1, INPUT_PULLUP);
  pinMode(3, INPUT_PULLUP);
  pinMode(4, INPUT_PULLUP);
  pinMode(5, INPUT_PULLUP);
  pinMode(6, INPUT_PULLUP);
  pinMode(7, INPUT_PULLUP);
  pinMode(8, INPUT_PULLUP);
  pinMode(9, INPUT_PULLUP);
  pinMode(10, INPUT_PULLUP);
Is there any way to tell the program that I want 10 pins to be granted an internal pull up resistor in one line of code?
To list all 10 pins as a comma separated list…
A first step would be to use a for loop
for (int pin = 0; pin < 11; pin++)
  pinMode(pin, INPUT_PULLUP);
I assume there are other ways of doing it by accessing the ports directly but the code won’t be so obvious.
Since the OP's list of pins is not continuous, some changes will be needed. Hint: an array of pin numbers.
How would I do that?
pinMode(n++, INPUT_PULLUP);
How would you do what?
PaulS:
Since the OP’s list of pins is not continuous, some changes will be needed. Hint: an array of pin numbers.
Quite right. I had missed the fact that pin 2 was missing from the sequence.
byte myPins[] = {0,1,3,4,5,6,7,8,9,10};
for (int pin = 0; pin < 10; pin++)
  pinMode(myPins[pin], INPUT_PULLUP);
I did too, until I noticed the first pin was 0 and the last was 10, and that OP said there were 10 pins. 0 to 10 is 11, so I had to pay attention.
Thanks. I forgot C syntax because I didn't use it in a long long time.
