What wrong with this code ?
Hi all.
My code ocasionally hangs… or self reset (once per one-two days). Then on oled it is incomplete text.
It seems to me that it is a deficiency of free SRAM. This program uses 690 B of 2048 B SRAM (as indicated by the arduino).
What is the reason for this behavior?
It’s possible that I have a significant error in the code?
#include <SerialGSM.h>
#include <SoftwareSerial.h>
SerialGSM cell(2, 3);
#include <OneWire.h>
OneWire  ds(9);
#define I2C_ADDRESS 0x3C
#include "AvrI2c.h"
#include "SSD1306Ascii.h"
#include "SSD1306AsciiAvrI2c.h"
SSD1306AsciiAvrI2c oled;
#include <EEPROM.h>
unsigned long previousMillis2 = 0;
float celsius;
  oled.begin(&Adafruit128x64, I2C_ADDRESS);
  oled.setFont(System5x7);
  oled.clear();
  oled.println(F("Wait 20 sec.."));
  //Serial.begin(57600);
  cell.begin(19200);
  cell.Verbose(true);
  cell.Boot();
  cell.DeleteAllSMS();
  cell.FwdSMS2Serial();
  boolean aaa = 0;
  while (cell.ReadLine()) {
    if ( strstr(cell.Message(), "OK") != NULL ) {
      aaa = 1;
      delay(10);
  if (aaa) {
    oled.clear();
    oled.println(F("OK - FOUND"));
    oled.clear();
    oled.println(F("Reset.."));
    cell.Boot();
      delay(10);
  celsius = temperature();
  delay(10);
  displaytemp();
  delay(10);
  if (cell.ReceiveSMS()) {
    //  Serial.println(cell.Sender());
    //  Serial.println(cell.Message());
    if ( strstr(cell.Message(), "TT.TEMP") != NULL) tttemp();
    if ( strstr(cell.Message(), "TT.ALARM:") != NULL) ttalarm();
    if ( strstr(cell.Message(), "TT.TELTEMP:") != NULL) tttel();
    if ( strstr(cell.Message(), "TT.INTERVAL:") != NULL) ttinterval();
    if ( strstr(cell.Message(), "TT.CHECK") != NULL) ttcheck();
    if ( strstr(cell.Message(), "TT.SETUP") != NULL) ttsetup();
  delay(10);
  alarmtest();
float temperature() {
  byte data[12];
  byte addr[8];
  if ( !ds.search(addr)) {
    ds.reset_search();
    return -300;
  ds.reset();
  ds.select(addr);
  ds.write(0x44, 1);
  ds.reset();
  ds.select(addr);
  ds.write(0xBE);
  for (byte i = 0; i < 9; i++) {
    data[i] = ds.read();
  ds.reset_search();
  float raw = (data[1] << 8) | data[0];
  float cels = raw / 16.0;
  return cels;
void tttemp() {
  cell.Rcpt(cell.Sender());
  cell.StartSMS();
  cell.print(F("Temperature at home: "));
  cell.print(celsius);
  cell.print(F("'C"));
  cell.EndSMS();
  cell.ReadLine();
void ttalarm() {
  char *mess = cell.Message();
  char alarmo[3];
  for (byte i = 0; i < 2; i++) {
    alarmo[i] = *(mess + 9 + i);
  alarmo[2] = '\0';
  byte n = atoi(alarmo);
  EEPROM.write(9, n);
  delay(100);
  cell.StartSMS();
  cell.print(F("Alarm setup: "));
  cell.print(n);
  cell.EndSMS();
  cell.ReadLine();
void tttel() {
  char bufftel[13];
    bufftel[i] = *(mess + 11 + i);
    EEPROM.write(i, bufftel[i]);
  bufftel[9] = '\0';
  cell.StartSMS();
  cell.print(F("Telephone setup: "));
    cell.print(bufftel[i]);
  cell.EndSMS();
  cell.ReadLine();
void ttinterval() {
  char inter[2];
  inter[0] = *(mess + 12);
  inter[1] = '\0';
  byte m = atoi(inter);
  EEPROM.write(10, m);
  cell.StartSMS();
  cell.print(F("Interval setup: "));
  cell.print(m);
  cell.print(F(" hours."));
  cell.EndSMS();
  cell.ReadLine();
void ttcheck() {
  cell.CheckBalance();
  cell.StartSMS();
  cell.print(F("Prepaid balance: "));
  cell.print(cell.Stanval());
  cell.print(F("va /"));
  cell.print(cell.Standay());
  cell.print(F("days."));
  cell.EndSMS();
  cell.ReadLine();
void ttsetup() {
  cell.StartSMS();
  cell.print(EEPROM.read(10));
  cell.println(F(" hours."));
    cell.print(char(EEPROM.read(i)));
  cell.println(F("."));
  cell.print(EEPROM.read(9));
  cell.println(F("'C"));
  cell.EndSMS();
  cell.ReadLine();
void displaytemp() {
  oled.clear();
  oled.println(F("Thermometer GSM"));
  oled.println();
  oled.set2X();
  oled.print(celsius);
  oled.println(F("'C"));
  oled.set1X();
void alarmtest() {
  byte alarm = EEPROM.read(9);
  if (celsius < alarm) {
    unsigned long interval2 = EEPROM.read(10);
    interval2 = interval2 * 3600000;
    if (currentMillis - previousMillis2 >= interval2) {
      previousMillis2 = currentMillis;
      char bufftel[13];
      bufftel[0] = '+';
      bufftel[1] = '1';
      bufftel[2] = '1';
        bufftel[i + 3] =  EEPROM.read(i);
      bufftel[12] = '\0';
      cell.Rcpt(bufftel);
      cell.StartSMS();
      cell.print(F("Temperature alarm: "));
      cell.EndSMS();
      cell.ReadLine();
Is shifting a byte and anding a byte really going to produce a float? Not in my universe.
I find it hard to believe that with an OLED display with fonts, etc., that you are only using 690 bytes of SRAM.
  char inter[2];
  inter[1] = '\0';
Or
byte m = *(mess + 12) - '0';
Just to point out another bug:
Any byte shifted left 8 bits will be 0. Think about it in binary:
00000001  start with 1 as an example
00000010  shift left once
00000100  twice
00001000  three times
00010000  four times
00100000  five times
01000000  six times
10000000  seven times
00000000  eight times - the last bit of the starting number just "fell off" the left side
(Technically, the result is undefined, but this is the practical result).
–Doug
dnwheeler:
00000100  twice
00010000  four times
00100000  five times
01000000  six times
00000000  eight times - the last bit of the starting number just “fell off” the left side
--Doug
The byte will be promoted to int for the arithmetic.
An int is 16 bits on an eight bit Arduino, and 1 can happily be shifted eight places left in a sixteen bit variable.(though a cast to an unsigned type is advisable)
This simple code uses only 34 Bytes of SRAM and 2728 Bytes of Flash. More here: http://forum.arduino.cc/index.php?topic=335594.0
#include "AvrI2c.h"
  oled.clear();
  oled.println(F("Hello"));
