Im using an arduino duemilanove and an HS-322HD stepper motor. When I plug it in and use even simple sample code the motor wont run. If i compile the code, then unplug it the motor will turn some odd degrees 7-8 times then stop. Ive tried everything from messing with the baud rate to the COM ports and nothing seems to affect the motor. I have a charger and a USB cable so i don't think power is the problem. Ive used 2 different computers and it does the same thing on both?
Im pretty sure im missing something obvious. Does anyone have an idea?
First off, terminology: The HS-322HD is a servo, not a stepper. Big difference.
Secondly, can you supply us with -your- schematic/hookup diagram and the code -you- are using (don't just point us to things online - we need to see what you are doing, not what somebody else has done - simply because you may have made a mistake with the code or wiring, and we can't see that with somebody else's diagram/code).
Just to verify - from your servo; you have the black wire going to ground, red to power (4.8 to 6 volts), and the white wire connected to pin 9, right?
What Pauly was asking about was whether you were driving the servo with a separate supply (this can be important, as the regulator on the Arduino may not be powerful enough to supply current for both the Arduino and the servo)...?
Also - have you tested this servo in any other manner to verify that it is good and working (servo tester, r/c radio, etc)? If not, you might want to check this as well - even "brand new" servos can be "dead" from the shop (generally because of vendor "return and resell" more than anything - but sometimes, even the factory ships out dud servos).
