What?!?!
hi i've been working on an project for quite some time and when uploading my code this error came up
error: expected unqualified-id before numeric constant in function 'void loop()'
Now here is the code i got the error from
const int led1=12;
const int led2=11;
const int led3=10;
const int led4=9;
const int led5=8;
const int led6=7;
const int led7=6;
const int led8=5;
const int led9=4;
const int led10=3;
const int missle=13;
const int power=2;
int switchstate=0
void setup () {
pinMode(led1,OUTPUT);
pinMode(led2,OUTPUT);
pinMode(led3,OUTPUT);
pinMode(led4,OUTPUT);
pinMode(led5,OUTPUT);
pinMode(led6,OUTPUT);
pinMode(led7,OUTPUT);
pinMode(led8,OUTPUT);
pinMode(led9,OUTPUT);
pinMode(led10,OUTPUT);
pinMode(power,OUTPUT);
pinMode(missle,INPUT);
void loop () {
switchstate=digitalRead(missle);
if (swithcstate==HIGH);
digitalWrite(led1,HIGH);
digitalWrite(led2,HIGH);
digitalWrite(led3,HIGH);
digitalWrite(led4,HIGH);
digitalWrite(led5,HIGH);
digitalWrite(led6,HIGH);
digitalWrite(led7,HIGH);
digitalWrite(led8,HIGH);
digitalWrite(led9,HIGH);
digitalWrite(led10,HIGH);
digitalWrite(led10,LOW);
digitalWrite(led9,LOW);
digitalWrite(led8,LOW);
digitalWrite(led7,LOW);
digitalWrite(led6,LOW);
digitalWrite(led5,LOW);
digitalWrite(led4,LOW);
digitalWrite(led3,LOW);
digitalWrite(led2,LOW);
digitalWrite(led1,LOW);
digitalWrite(power,HIGH);
else{
digitalWrite(power,LOW);
If you can please help
int switchstate=0
void setup () {
You need one of these ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
Would be nice to post code properly, tto, using the # button. Please modify your post, select all the code (yeah, it will take a while), and select the # button. Then, save.
By the way, arrays and for loops would cut down drastically on the amount of code you are using.
This ; at the end of the if will give you problems if you dont remove it the code inside the {} will be always executed because its outside the if.
this line needs a semicolon:
int switchstate=0
typo in spelling of switchstate here:
and you don't want the semicolon at the end of the above line
should be
if (switchstate==HIGH) // NO SEMICOLON HERE
@OP, you must really like typing!
Your code should be about 20% of what you have written.
cool thanks for solving my problem
led1 stays HIGH you know. You can get rid of most of your code.
