What's best practice for soldering shottky diode with proto board?
I've a project in a 12V environment so intend to use this switching regulator in the circuit to supply 5V for ATmega328 & other logic. In the reference circuit it needs a shottky diode, an IN5822, but now I've received them I find their wire is too thick to fit in a regular through-hole stripboard/protoboard. Pragmatically, I was just going to drill out a pair of holes a bit bigger, but before I do...is there a better way you guys would recommend?
Also, any advice on how to use these when you're setting up a breadboard version? Clearly the drill isn't an option. At the moment I've got aligator clips connecting the off-board shottky but it's all a bit precarious.
Thanks for your thoughts & advice,
Geoff
Go with the drill.
Forget solder less bread board for this sort of circuit it is not going to work reliably because of the stray L and C on the board. In other words the very poor layout you will get.
Grumpy_Mike:
Go with the drill.
Thanks Mike. Always happy for an excuse to fire up the drill press. Even happier if it's truly justified :slight_smile:
You think you've got problems. I have these bad boys to try and deal with. Common cathode 40A dual schottky's.
For scale, that's an LM317T in a normal TO220 package next to it :slight_smile:
Thats easy... just drill larger holes... Doesn't need an Engineer...
Doc
