Whats Blood pressure sensor
Hello, I would like to build an electronic tensiometer with Arduino I found these sensors:
But the shops are in India and I am in France.
Can you tell me a website that I can order and be delivered in a week.
or at least have a similar sensor. Thank you
Thank you,
The problem with this sensor is that it does not measure blood pressure.
And my goal is to build an electronic blood pressure monitor.
I would like an optical sensor like (https://protocentral.com/product/pulse-express-pulse-ox-heart-rate-sensor-with-max32664/) or with a cuff like (Blood Pressure Sensor Module With Ttl Output For Arduino And Microcontroller Projects at Rs 1500/unit | Pressure Sensor in Pune | ID: 21544478812).
Get a cheap, manual sphygmomanometer and hook this (linked) up in parallel to discover the range...
Thank you
But this pressure sensor is functional using a pump and a cuff.
Is there a complete module with cuff and pump like this (Blood Pressure Sensor Module With Ttl Output For Arduino And Microcontroller Projects at Rs 1500/unit | Pressure Sensor in Pune | ID: 21544478812) in Europe or America to do this?
Do you know of any E commerce website for sensors used in biomedical?
I think you want to use a traditional pump-and-cuff(-and-gauge) to sense and store the sensor data. I do not know of anything like that. I did a little reading and the linked sphygmomanometer was the only thing that I saw that was good (other than the pulse oximeter, which is used as BP is measured). For the sphyg. to accurately record data, you might try putting it in-line with the working gauge. Be sure the gauge still reads accurately. Write code that lets you calibrate the sphyg. so it reads exactly as the gauge.
