Well, most shields have noticeable added capabilities like Ethernet, storage, LCD etc.
I can't find something special in motor shield. Why do I need a shield for it? Why not simply supply direct current to the motors (from Arduino board or external)?
If you try to power a motor off of your board their is a 99% chance you will kill your Arduino. As for providing power to the motors from an external power supply that is what the shields does.
The arduino pins can only supply ~40ma max, which insufficient to drive most motors. Also motors produce voltage spikes when being switched on/off that might damage the arduino.
mightyaad:
Really? Which one are you looking at?
Mine has an L298 motor driver IC, a 4077 CMOS nor gate IC, a bunch of schottky diodes, resistors, capacitors, LEDs. It also has connections for sensors, servos, motors, and an external power supply from which to drive them so I don't burn out my Arduino by running too much current through it.
