whats the difference between two sketch arduino nano ethernet
Hello,
i upload the default Ethernet/WebServer example, but it never takes ip. then i changed the library and upload UIPEthernet then it works fine. here is the codes for UIPEthernet and see attached UIPEthernet_library.zip
whats the gap in the default ethernet webserver sketch? How can we modify the default webserver.ino?
// UIP is a proper library for Arduino Nano Ethernet shield
// NOTE: UIPEthernet library is not needed if you are using Arduino UNO/Duemilanove/Mega/etc.
// UIPEthernet library is used for Arduino Nano Ethernet Shield
#include <UIPEthernet.h> // Used for Ethernet
// **** ETHERNET SETTING ****
byte mac = { 0x90, 0xA2, 0xDA, 0x0D, 0x78, 0xEE };
IPAddress ip(192, 168, 1, 115);
EthernetServer server(80);
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
Serial.print("IP Address: ");
Serial.println(Ethernet.localIP());
// listen for incoming clients
if (client)
Serial.println("-> New Connection");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected())
if (client.available())
char c = client.read();
// if you’ve gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == ‘\n’ && currentLineIsBlank)
client.println(“Hello World!
Hello World!
if (c == ‘\n’) {
// you’re starting a new line
else if (c != ‘\r’)
// you’ve gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(10);
// close the connection:
client.stop();
Serial.println(" Disconnected\n");
UIPEthernet_library.zip (101 KB)
