what's the different between int & byte, while i=0
int pin = {
2,3,4,5,6,7,8,9,10,11};
void setup(){
for(int i = 0; i <= 9; i++){
pinMode( pin*,OUTPUT);*
    void rt(){
  • for(byte i = 9; i >= 0; i–){*
    _ digitalWrite(pin*,HIGH);_
    _
    delay(50);_
    _ digitalWrite(pin,LOW);
    void loop(){
    rt();
    show noise :-/_
The difference is that the compiler will use a single 8 bit variable for the counter in the machine language it produces rather then a 16 bit variable. The object code produced is 10 bytes smaller then it would be if int was used in that loop rt instead of byte.
You can use byte when you are absolutely sure that your variables will never exceed 255 (or +- 127 if signed)
But int is safer from overflow bugs and the slight loss in program size and efficiency usually doesn't matter,
But, while byte i = 0 the program don't stop loop in the for(byte i = 9; i >= 0; i--){} continue to do i-- 10 times, so you'll get 255 254 253 252 251 250 249 248 247 246 maybe ONE bug ?
A byte only goes from 0 to 255. So i >= 0 is always true (if i is a byte). When you subtract 1 from a byte with a value of 0, it wraps around and you get 255. You could change the loop to for (byte i = 10; i > 0; i--) and then use (i - 1) inside the loop.
