Sometimes, I see one of the functions inside the code, but sometimes I see both of the functions inside the code
is ISR a user defined function that associated with a vector
ISR( vector )
AttachInterrupt(interrupt pin, isr, ..) sometimes I see onky attachinterrupt function without the ISR(vector) function,
It's associated a pin change with a certain isr but this isr doesn't have the format of ISR(vector) . Instead it just any defined function such as wake(). In this case, is there a certain interrupt vector from the table associated with AttachInterrupt?
Sometimes I see both AttachInterrupt and ISR(vector) functions in the code.
Why there are 3 different scenarios with Interrupts?
Above example,
So base on the table pin 13 belongs vector 4 or PCINT0_vect, right?
Since in this example, I defined a custom ISR therefore the macro
ISR(PCINT0_vect) { } would be empty inside?
1 Reset
2 External Interrupt Request 0 (pin D2) (INT0_vect)
3 External Interrupt Request 1 (pin D3) (INT1_vect)
4 Pin Change Interrupt Request 0 (pins D8 to D13) (PCINT0_vect)
5 Pin Change Interrupt Request 1 (pins A0 to A5) (PCINT1_vect)
6 Pin Change Interrupt Request 2 (pins D0 to D7) (PCINT2_vect)
7 Watchdog Time-out Interrupt (WDT_vect)
8 Timer/Counter2 Compare Match A (TIMER2_COMPA_vect)
9 Timer/Counter2 Compare Match B (TIMER2_COMPB_vect)
10 Timer/Counter2 Overflow (TIMER2_OVF_vect)
11 Timer/Counter1 Capture Event (TIMER1_CAPT_vect)
12 Timer/Counter1 Compare Match A (TIMER1_COMPA_vect)
13 Timer/Counter1 Compare Match B (TIMER1_COMPB_vect)
14 Timer/Counter1 Overflow (TIMER1_OVF_vect)
15 Timer/Counter0 Compare Match A (TIMER0_COMPA_vect)
16 Timer/Counter0 Compare Match B (TIMER0_COMPB_vect)
17 Timer/Counter0 Overflow (TIMER0_OVF_vect)
18 SPI Serial Transfer Complete (SPI_STC_vect)
19 USART Rx Complete (USART_RX_vect)
20 USART, Data Register Empty (USART_UDRE_vect)
21 USART, Tx Complete (USART_TX_vect)
22 ADC Conversion Complete (ADC_vect)
23 EEPROM Ready (EE_READY_vect)
24 Analog Comparator (ANALOG_COMP_vect)
25 2-wire Serial Interface (I2C) (TWI_vect)
26 Store Program Memory Ready (SPM_READY_vect)
