What's this called when 2 Power Sources...
2 power sources are connected together... for simplicity sake.
2 12v lead acid batteries, - to + and + to - where the wires meet where do the electrons flow? a simulator just says a short but what actually goes on here? the energy is way more intense than just a direct short.. so what's going on here?
it is a short : you wire two 12V batteries in serie , and you short the + and the - , you've just short a 24V battery ;)
don't touch the wire that makes the short, it will burn your hand very quickly (yes, I tried once : a piece of metal shortened the battery of my car, before I could take it off, it became red, then white, and my hand was on it !! )
yeah, but a straight short, from - to + is bad.
I once connected a 1amp 19v charger backwards (without a diode or anything to protect it) back to front and that wire that connected to the alligator clip simply vanished in a poof of smoke!
(i was half asleep at the time, wide awake shortly after the small explosive charge)
cjdelphi: 2 power sources are connected together... for simplicity sake.
If both batteries are in good nick this is just like shorting both of them out, the current's the same, the voltage is all dropped across internal resistance and cable resistance dumping ~10 kW into both.
However if you don't fully short them out there is twice the voltage available to hold a DC spark, which will then be ~4 times as powerful as one battery (but this is just a DC load, not a true short ciircuit!)
High power DC arcs are pretty stable (arc welding), especially at higher voltages, and the size depends on the available power more than anything. The length of the arc can be longer with higher voltages, but high power also helps.
do you mean simply two batteries in parallel? should be ok if they're both the same type and at the same charge state will simply double the capacity
no, imagine jump starting a car, but instead you cross the leads.
Say bye to the jumper cable lol... maybe even a splash of acid lol, no I was trying to work out if it's just 2 12v shorts or 24vs of short and where the electrons were traveling since there's 2 grounds.
either way don't do it unless you like burnt fingers...
on another note, getting a lithium 3v watch battery too hot makes it go bang, but it had a nice fragrance when it did....
It is shorting. Batteries are made from multiple cells, when you connect on + to one -, you are connecting another battery in series or in other words, just adding more cells to the system. When you connect remaining + and -, you are doing the same thing as a short with one battery, only with twice as much available energy.
cjdelphi: no, imagine jump starting a car, but instead you cross the leads.
The electrons are going round in circles. I hear that they get dizzy :) There's no difference between two 12V batteries connected in series and one 24V battery, so there's not 2 grounds. By shorting them/it out, you could say that there's no ground at all, as the -ve terminal is connected to the +ve terminal.
Good advice.
I call it assault on batteries. g'heh..
SirNickity: I call it assault on batteries. g'heh..
I'm positive that you should be on a charge for that comment.
ooh lots of molten jumper leads, sparks, sore hands :) generally not recommended!
but as others have said it's like simply connecting a very low resistance across a low impedance 24 volt source so v high current until something gives up
alternatively first think of the setup as two 12 volt batteries in series ( = 24 volts) the -ve of one is ground the +ve of t'other is 24 volts the middle ( +ve of 1st, -ve of second) is "just" a centre tap
now put your zero-ohm load (the other wire) from +24v and gnd stand well back!
