whats this
WARNING: Category '' in library EEPROM is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library SPI is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library SoftwareSerial is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library Wire is not valid. Setting to 'Uncategorized'
Warning: platform.txt from core 'Arduino AVR Boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
Any ideals what this is about thanks
Please put your code in its own window as seen in other posts. This can be done by placing     [code]  and [/code]  around the code or use the </> icon. This makes it easier for others to read.
How to use this forum
We cannot see what you have done wrong if you don't supply your code.
Weedpharma
any and all example codes ran produces the following warnings, then uploads the program.All started after new update
Bairzillia:
This indicates you are using an outdated version of the Arduino AVR Boards. To update just do Tools > Board > Boards Manager > Arduino AVR Boards > Update.
Bairzillia:
These warnings could be caused by the outdated Arduino AVR Boards version. If so, doing the above update will fix it. It could also be caused by a different boards package you have installed. The invalid category warnings can be safely ignored. Most packages should have fixed this issue by now but if not it can be silenced by opening the library.properties file of each of these libraries and adding the line
category=Other
You'll get these warnings regardless of what your code is so this is actually the rare case where it would be pointless for you to post it. However, you should use code tags when posting warnings/errors or other console output.
updated arduino board version to 1.6.9 warnings went away. Thanks Pert
