What's wrong ? Using servo motor
Hi, I tryed to write a program, but something dont work : servos are’nt moving :frowning:
Do someone could explain me why ? :confused:
#include <Servo.h>
Servo servo_s;
Servo servo_m;
Servo servo_pin_10h
int m;
int h;
Serial.begin(9600); // Vitesse de transmission compatible avec le fichier Processing.
servo_s.attach(8);
servo_m.attach(9);
servo_h.attach(10);
servo_s.write( s );
servo_m.write( m );
servo_h.write( h );
s=0;
m=0;
h=0;
servo_s.write( 3s );
servo_m.write( 3
m );
servo_h.write( 7.5*h );
delay (1000);
s=s+1;
if (s=60)
s=0;
m=m+1;
m=m+s/60;
if (m=60)
m=0;
h=h+1;
h=h+m/60;
if (h=24)
h=0;
if (s=60)oops
Oops ? :s
First of all you have not created a servo object called servo_h
Second the servo.write() function requires the number of degrees (between 0 and 180) that your servo should move to.
You seem to be trying to use a variable called 's' that you have not created.
The variables m and h will be initialized to 0 and I presume you know that (for example) 3 * 0 always gives 0
See what happens if you do something simple like servo_s.write(90);
All tests for the value of a variable require == for example if (s == 60) {
In general use meaningful names for all your variables, not single letters.
...R
Planning and Implementing a Program
Ohh i understand !
It works no, thank you !!
#include <Servo.h>
Servo servo_s;
Servo servo_m;
Servo servo_h;
int s;
int m;
int h;
servo_s.attach(8);
servo_m.attach(9);
servo_h.attach(10);
servo_s.write( s );
servo_m.write( m );
servo_h.write( h );
s=0;
m=0;
h=0;
servo_m.write( 3
m );
delay (1000);
s=s+1;
if (s=60)
s=0;
m=m+1;
m=m+s/60;
if (m=60)
m=0;
h=h+1;
h=h+m/60;
if (h=24)
h=0;
HugoMenager:
Oops ? :s
sorry, that should be oops3
You have a strange definition of "works"
(deleted)
It works without " == ", i just added "else" afet "if" :slight_smile:
HugoMenager:
See reply #6
HugoMenager:
Your idea of working must be different to mine.
Do you understand the difference between = and == ?
UKHeliBob:
Not really.. Is "==" for testing something and "=" to change a value ?
Yes.
That's a pretty big difference, don't you think?
Pretty big yeah :S
HugoMenager:
Pretty big yeah :S
Now that you know the difference do you still think that your code works ?
