I'm wondering if anyone can tell me all the problems with this code?
unsigned long previousMillis = 0;
const long interval = 1;
#include "Full.c"
#include "Draining.c"
#include "Drained.c"
#include "Empty.c"
#include "Charging.c"
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 2
#define TEMPERATURE_PRECISION 1000
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
#define USE_TOUCH 0x2046
#include <virtuabotixRTC.h> //Libraries needed
virtuabotixRTC myRTC(6, 7, 8);
#include "Adafruit_GFX.h" // Hardware-specific library
#include <MCUFRIEND_kbv.h>
#include <SPI.h>
#include <SD.h>
MCUFRIEND_kbv tft; //
#define TFT_BEGIN() tft.begin(0x9488)
#include <XPT2046_Touchscreen.h> // Hardware SPI library
char *name = "Shield XPT2046 Calibration"; //edit name of shield
const int TS_LANDSCAPE = 1; //XPT2046_TouchScreen.h
const int TS_LEFT = 261, TS_RT = 3770, TS_TOP = 3869, TS_BOT = 296;
#define XPT_CS 53 // MEGA2560 SHIELD
#define XPT_IRQ 255 // XPT2046 library does not like IRQ
XPT2046_Touchscreen ts(XPT_CS, XPT_IRQ);
int pixel_x, pixel_y; //Touch_getXY() updates global vars
bool Touch_getXY(void)
bool pressed = ts.touched();
if (pressed) {
TS_Point p = ts.getPoint();
if (TS_LANDSCAPE) mapxy(p.y, p.x);
else mapxy(p.x, p.y);
return pressed;
void Touch_init(void)
ts.begin();
void mapxy(int x, int y) //maps ADC to pixel_x, pixel_y
int aspect = tft.getRotation(); //LANDSCAPE
int tft_width = tft.width();
int tft_height = tft.height();
switch (aspect & 3) {
case 0: //PORTRAIT
pixel_x = map(x, TS_LEFT, TS_RT, 0, tft_width);
pixel_y = map(y, TS_TOP, TS_BOT, 0, tft_height);
case 1: //LANDSCAPE
pixel_x = map(y, TS_TOP, TS_BOT, 0, tft_width);
pixel_y = map(x, TS_RT, TS_LEFT, 0, tft_height);
case 2: //PORTRAIT REV
pixel_x = map(x, TS_RT, TS_LEFT, 0, tft_width);
pixel_y = map(y, TS_BOT, TS_TOP, 0, tft_height);
case 3: //LANDSCAPE REV
pixel_x = map(y, TS_BOT, TS_TOP, 0, tft_width);
pixel_y = map(x, TS_LEFT, TS_RT, 0, tft_height);
Adafruit_GFX_Button temp_btn, humidity_btn, home_btn, more_btn;
#define BLACK 0x0000 /* 0, 0, 0 */
#define NAVY 0x000F /* 0, 0, 128 */
#define DARKGREEN 0x03E0 /* 0, 128, 0 */
#define DARKCYAN 0x03EF /* 0, 128, 128 */
#define MAROON 0x7800 /* 128, 0, 0 */
#define PURPLE 0x780F /* 128, 0, 128 */
#define OLIVE 0x7BE0 /* 128, 128, 0 */
#define LIGHTGREY 0xC618 /* 192, 192, 192 */
#define DARKGREY 0x7BEF /* 128, 128, 128 */
#define BLUE 0x001F /* 0, 0, 255 */
#define GREEN 0x07E0 /* 0, 255, 0 */
#define CYAN 0x07FF /* 0, 255, 255 */
#define RED 0xF800 /* 255, 0, 0 */
#define MAGENTA 0xF81F /* 255, 0, 255 */
#define YELLOW 0xFFE0 /* 255, 255, 0 */
#define WHITE 0xFFFF /* 255, 255, 255 */
#define ORANGE 0xFD20 /* 255, 165, 0 */
#define GREENYELLOW 0xAFE5 /* 173, 255, 47 */
#define PINK 0xF81F
uint8_t displayScreenNo, prevDay, prevMonth, prevSec, prevMin, prevHour, prevVolt, prevMoon;
uint16_t prevYear;
static float prevTemp = 999.99 ; // an unlikely value
float currentTempF = sensors.getTempCByIndex(0) ;
Serial.begin(2000000);
sensors.begin();
sensors.setResolution(12);
TFT_BEGIN();
Touch_init();
tft.setRotation(1); //PORTRAIT
tft.fillScreen(BLACK);
home_btn.initButton(&tft, 440, 280, 80, 80, LIGHTGREY, CYAN, BLACK, "HOME", 2);
home_btn.drawButton(false);
more_btn.initButton(&tft, 440, 40, 80, 80, LIGHTGREY, CYAN, BLACK, "MORE", 2);
more_btn.drawButton(false);
temp_btn.initButton(&tft, 440, 120, 80, 80, LIGHTGREY, CYAN, BLACK, "TEMP", 2);
humidity_btn.initButton(&tft, 440, 200, 80, 80, LIGHTGREY, CYAN, BLACK, "%", 2);
temp_btn.drawButton(false);
humidity_btn.drawButton(false);
tft.setTextSize(3);
unsigned int IntensityOfLight;
IntensityOfLight = analogRead(A0);
myRTC.updateTime();
sensors.requestTemperatures();
bool down = Touch_getXY();
home_btn.press(down && home_btn.contains(pixel_x, pixel_y));
more_btn.press(down && more_btn.contains(pixel_x, pixel_y));
temp_btn.press(down && temp_btn.contains(pixel_x, pixel_y));
humidity_btn.press(down && humidity_btn.contains(pixel_x, pixel_y));
if (home_btn.justReleased()) {
home_btn.drawButton(true);
more_btn.drawButton();
temp_btn.drawButton();
humidity_btn.drawButton();
if (more_btn.justReleased()) {
more_btn.drawButton(true);
home_btn.drawButton();
if (temp_btn.justReleased()) {
temp_btn.drawButton(true);
if (humidity_btn.justReleased()) {
humidity_btn.drawButton(true);
if (home_btn.justPressed())
prevDay = 99;
prevMonth = 99;
prevYear = 9999;
prevHour = 99;
prevMin = 99;
prevSec = 99;
prevTemp = 999.99;
prevVolt = 9.99;
drawHomeScreen();
displayScreenNo = 1;
if (more_btn.justPressed())
prevDay = 99;
prevMonth = 99;
prevYear = 9999;
prevHour = 99;
prevMin = 99;
prevSec = 99;
prevTemp = 999.99;
prevVolt = 9.99;
drawMoreScreen();
displayScreenNo = 2;
if (temp_btn.justPressed())
prevDay = 99;
prevMonth = 99;
prevYear = 9999;
prevHour = 99;
prevMin = 99;
prevSec = 99;
prevTemp = 999.99;
prevVolt = 9.99;
drawDetailScreenTemp();
displayScreenNo = 3;
if (humidity_btn.justPressed())
prevDay = 99;
prevMonth = 99;
prevYear = 9999;
prevHour = 99;
prevMin = 99;
prevSec = 99;
prevTemp = 999.99;
prevVolt = 9.99;
drawDetailScreenHumidity();
displayScreenNo = 4;
switch (displayScreenNo)
case 1: drawDynHomeScreen(); break;
case 2: drawDynMoreScreen(); break;
case 3: drawDynDetailScreenTemp(); break;
case 4: drawDynDetailScreenHumidity(); break;
void drawHomeScreen() {
tft.drawLine(0, 27, 480, 27, LIGHTGREY);
tft.drawLine(0, 28, 480, 28, LIGHTGREY);
tft.drawLine(200, 0, 200, 28, LIGHTGREY);
tft.drawLine(201, 0, 201, 28, LIGHTGREY);
tft.drawLine(0, 288, 480, 288, LIGHTGREY);
tft.drawLine(0, 289, 480, 289, LIGHTGREY);
tft.drawLine(200, 288, 200, 320, LIGHTGREY);
tft.drawLine(201, 289, 201, 320, LIGHTGREY);
void drawDetailScreenHumidity() {
tft.drawLine(27, 33, 339, 33, LIGHTGREY);
tft.drawLine(27, 59, 339, 59, LIGHTGREY);
tft.drawLine(27, 85, 339, 85, LIGHTGREY);
tft.drawLine(27, 111, 339, 111, LIGHTGREY);
tft.drawLine(27, 137, 339, 137, LIGHTGREY);
tft.drawLine(27, 163, 339, 163, LIGHTGREY);
tft.drawLine(27, 189, 339, 189, LIGHTGREY);
tft.drawLine(27, 215, 339, 215, LIGHTGREY);
tft.drawLine(27, 241, 339, 241, LIGHTGREY);
tft.drawLine(27, 267, 339, 267, LIGHTGREY);
tft.drawLine(27, 293, 339, 293, LIGHTGREY);
tft.drawLine(339, 33, 339, 293, LIGHTGREY);
tft.drawLine(313, 33, 313, 293, LIGHTGREY);
tft.drawLine(287, 33, 287, 293, LIGHTGREY);
tft.drawLine(261, 33, 261, 293, LIGHTGREY);
tft.drawLine(236, 33, 236, 293, LIGHTGREY);
tft.drawLine(209, 33, 209, 293, LIGHTGREY);
tft.drawLine(183, 33, 183, 293, LIGHTGREY);
tft.drawLine(157, 33, 157, 293, LIGHTGREY);
tft.drawLine(131, 33, 131, 293, LIGHTGREY);
tft.drawLine(105, 33, 105, 293, LIGHTGREY);
tft.drawLine(79, 33, 79, 293, LIGHTGREY);
tft.drawLine(53, 33, 53, 293, LIGHTGREY);
tft.drawLine(27, 33, 27, 293, LIGHTGREY);
tft.setTextSize(1);
tft.setTextColor(LIGHTGREY);
tft.setCursor(2, 33);
tft.print("100%");
tft.setCursor(6, 59);
tft.print("90%");
tft.setCursor(6, 85);
tft.print("80%");
tft.setCursor(6, 111);
tft.print("70%");
tft.setCursor(6, 137);
tft.print("60%");
tft.setCursor(6, 163);
tft.print("50%");
tft.setCursor(6, 189);
tft.print("40%");
tft.setCursor(6, 215);
tft.print("30%");
tft.setCursor(6, 241);
tft.print("20%");
tft.setCursor(6, 267);
tft.print("10%");
tft.setCursor(6, 293);
tft.print("0%");
tft.setTextSize(1);
tft.setCursor(26, 300);
tft.print("6");
tft.setCursor(44, 300);
tft.print("5.5");
tft.setCursor(77, 300);
tft.print("5");
tft.setCursor(96, 300);
tft.print("4.5");
tft.setCursor(128, 300);
tft.print("4");
tft.setCursor(148, 300);
tft.print("3.5");
tft.setCursor(181, 300);
tft.print("3");
tft.setCursor(200, 300);
tft.print("2.5");
tft.setCursor(234, 300);
tft.print("2");
tft.setCursor(253, 300);
tft.print("1.5");
tft.setCursor(285, 300);
tft.print("1");
tft.setCursor(305, 300);
tft.print("0.5");
tft.setCursor(337, 300);
tft.print("0");
void drawMoreScreen() {
void drawDetailScreenTemp() {
tft.setTextSize(1);
tft.setCursor(6, 33);
tft.print("45");
tft.print((char)247);
tft.print("40");
tft.print("35");
tft.print("30");
tft.print("25");
tft.print("20");
tft.print("15");
tft.print("10");
tft.print(" 5");
tft.print(" 0");
tft.setCursor(6, 285);
tft.print("-5");
tft.setTextSize(1);
tft.print("6");
tft.print("5.5");
tft.print("5");
tft.print("4.5");
tft.print("4");
tft.print("3.5");
tft.print("3");
tft.print("2.5");
tft.print("2");
tft.print("1.5");
tft.print("1");
tft.print("0.5");
tft.print("0");
void battery () {
int sensor = analogRead(A1);
//Serial.println(sensor);
float voltage = (sensor * 5.0) / 1023;
//Serial.println(voltage);
if (voltage > 3.00) {
tft.drawRGBBitmap(355, 3, Charging, 36, 21);
if ((voltage <= 3.00) && (voltage > 2.35)) {
tft.drawRGBBitmap(355, 3, Full, 36, 21);
if ((voltage <= 2.35) && (voltage > 1.70)) {
tft.drawRGBBitmap(355, 3, Draining, 36, 21);
if ((voltage <= 1.70) && (voltage > 1.00)) {
tft.drawRGBBitmap(355, 3, Drained, 36, 21);
if (voltage <= 1.00) {
tft.drawRGBBitmap(355, 3, Empty, 36, 21);
void buttons () {
void drawDynHomeScreen() {
tft.setTextSize(3);
tft.setTextColor(WHITE);
if (myRTC.dayofmonth != prevDay)
prevDay = myRTC.dayofmonth;
tft.fillRect(5, 3, 33, 21, BLACK);
tft.setCursor(5, 3);
if (myRTC.dayofmonth < 10)
tft.print("0");
tft.print(myRTC.dayofmonth);
tft.setCursor(41, 3);
tft.print("/");
if (myRTC.month != prevMonth)
prevMonth = myRTC.month;
tft.fillRect(59, 3, 33, 21, BLACK);
tft.setCursor(59, 3);
if (myRTC.month < 10) {
tft.print("0");
tft.print(myRTC.month);
else {
tft.setCursor(95, 3);
tft.print("/");
if (myRTC.year != prevYear)
prevYear = myRTC.year;
tft.fillRect(113, 3, 70, 21, BLACK);
tft.setCursor(113, 3);
tft.print(myRTC.year);
if (myRTC.hours != prevHour)
prevHour = myRTC.hours;
tft.fillRect(206, 3, 33, 21, BLACK);
tft.setCursor(206, 3);
if (myRTC.hours < 10) {
tft.print("0");
tft.print(myRTC.hours);
else {
tft.setCursor(239, 3);
tft.print(":");
if (myRTC.minutes != prevMin)
prevMin = myRTC.minutes;
tft.fillRect(256, 3, 33, 21, BLACK);
tft.setCursor(256, 3);
if (myRTC.minutes < 10) {
tft.print("0");
tft.print(myRTC.minutes);
else {
tft.setCursor(290, 3);
tft.print(":");
if (currentMillis - previousMillis >= interval) {
if (myRTC.seconds != prevSec)
prevSec = myRTC.seconds;
tft.fillRect(306, 3, 33, 21, BLACK);
tft.setCursor(306, 3);
if (myRTC.seconds < 10) {
tft.print("0");
tft.print(myRTC.seconds);
Serial.print("0");
Serial.println(myRTC.seconds);
else {
if (voltage != prevVolt)
prevVolt = voltage;
battery();
// abs() is a special Arduino function defined in Arduino.h but maybe not on all platforms
// in case of problems, look at fabs() instead.
if ( abs( currentTempF - prevTemp ) > 0.01 ) // if the value change is outsid 0.01 degrees C
prevTemp = currentTempF ;
tft.setCursor(5, 294);
tft.fillRect(5, 294, 90, 21, BLACK);
tft.print( currentTempF );
tft.print(" ");
tft.print("C");
void drawDynDetailScreenHumidity() {
myRTC.updateTime();
tft.setTextSize(3);
tft.print("0");
tft.print("/");
tft.print("0");
else {
tft.print("/");
tft.print("0");
else {
tft.print(":");
tft.print("0");
else {
prevVolt = voltage;
battery();
void drawDynMoreScreen() {
buttons();
void drawDynDetailScreenTemp() {
myRTC.updateTime();
tft.setTextSize(3);
tft.print("0");
tft.print("/");
tft.print("0");
else {
tft.print("/");
tft.print("0");
else {
tft.print(":");
tft.print("0");
else {
prevVolt = voltage;
battery();
A few things aren't working correctly, and I don't know how to fix them.
Temperature never updates on the home screen unless I reset the board
I don't know how to plot the data from the DS18B20 onto the graphs I've drawn
Apart from that I want to know if anyone sees issues with the code that will cause long-term issues.
I have posted detailed topics on the first two issues, this post isn't directed to fixing those, it is directed to fixing the third question. I am not tring to cross post, but let me know if this is an issue here.
I know the code is a mess, I am trying to make it make more sense, but I'm not great at making my code make sense to other people. It always makes sense to me though! Well, 2% of the time it makes sense to me anyway!!
