what's wrong with my heart rate sensor?
i was looking at my arduino serial plotter. When I have my heart rate sensor plugged in with no skin contact, and pointed away from me, I have this periodic oscillation. the oscillation pattern is pretty constant, as well as the period (~2seconds).
see the wave toward the right? it looks just like a heart beat... i got all excited over nothing :frowning:
when i unplug everything i get a pretty consistent flat line. when i plug in a piece of wire i pick up noise that's pretty consistent, no oscillatory patterns with a period of 2s.
is it the circuit?
code?
void setup(){
  Serial.begin();
  pinMode(SDA, INPUT);
void loop(){
  int a = Serial.Read(SDA);
  Serial.prinln(a);
yea.. sorry to disappoint :frowning:
I thought your code could point to a 2 sec period, but that free-running code runs as fast as serial-graph can print.
Try adding some millisec delay - just to see if the mysterious pattern changes. The printbuffer is overrun ?
That code doesn't compile.
Pete
bmarconi:
is it the circuit?
It is likely something else in the room.
It could even be the uP beating with the
60 cycle noise.
To be useful, you need to connect a load on the
probe inputs, similar to your body.
If it is dry contact 100K is about right.
Wet, about 5K.
Dwight
dwightthinker:
60 cycle noise.
Wet, about 5K.
Dwight
Dwight, you might be a little too late - it’s a 7-month old thread. Hopefully he/she has sorted it out by now.
@snehawarade1990, it’s not a good idea to dredge up old threads then reply to them. It’s very confusing. :frowning:
Oops. 7 months, I have to look back.
There was a current blank post that tricked me.
Dwight
