I modified the NewPing 3 sensers example and got error, need help please. sorry about the elementary asking.
Thanks
Adam
Dual HC-SR04 with Temp and Humidity Demonstration
HC-SR04-Temp-Humid-Dual-Demo.ino
Demonstrates enhancements of HC-SR04 Ultrasonic Range Finder
With DHT22 Temperature and Humidity Sensor
Displays results on Serial Monitor
DroneBot Workshop 2017
http://dronebotworkshop.com
// Include DHT Libraries from Adafruit
// Dependant upon Adafruit_Sensors Library
#include "DHT.h";
// Include NewPing Library
#include "NewPing.h"
// Define Constants
#define DHTPIN 7 // DHT-22 Output Pin connection
#define DHTTYPE DHT22 // DHT Type is DHT 22 (AM2302)
#define TRIGGER_PIN_1 10
#define ECHO_PIN_1 10
#define TRIGGER_PIN_2 5
#define ECHO_PIN_2 5
#define MAX_DISTANCE 400
////// NewPing sonar1(TRIGGER_PIN_1, ECHO_PIN_1, MAX_DISTANCE);
////// NewPing sonar2(TRIGGER_PIN_2, ECHO_PIN_2, MAX_DISTANCE);
int i = 0;
uint8_t Trager[3]= {0};
uint8_t Echo[3]= {0};
uint8_t sonar[3]={0};
NewPing sonar[i](Trager[i], Echo[i], MAX_DISTANCE);
// Define Variables
float hum; // Stores humidity value in percent
float temp; // Stores temperature value in Celcius
float duration1; // Stores First HC-SR04 pulse duration value
float duration2; // Stores Second HC-SR04 pulse duration value
float distance1; // Stores calculated distance in cm for First Sensor
float distance2; // Stores calculated distance in cm for Second Sensor
float soundsp; // Stores calculated speed of sound in M/S
float soundcm; // Stores calculated speed of sound in cm/ms
int iterations = 5;
// Initialize DHT sensor for normal 16mhz Arduino
DHT dht(DHTPIN, DHTTYPE);
Serial.begin (9600);
dht.begin();
delay(1000); // Delay so DHT-22 sensor can stabalize
hum = dht.readHumidity(); // Get Humidity value
temp= dht.readTemperature(); // Get Temperature value
// Calculate the Speed of Sound in M/S
soundsp = 331.4 + (0.606 * temp) + (0.0124 * hum);
// Convert to cm/ms
soundcm = soundsp / 10000;
// Measure duration for first sensor
duration1 = sonar1.ping_median(iterations);
// Add a delay between sensor readings
duration2 = sonar2.ping_median(iterations);
// Calculate the distances for both sensors
distance1 = (duration1 / 2) * soundcm;
distance2 = (duration2 / 2) * soundcm;
// Send results to Serial Monitor
Serial.print("Distance 1: ");
if (distance1 >= 400 || distance1 <= 2) {
Serial.print("Out of range");
else {
Serial.print(distance1);
Serial.print(" cm ");
Serial.print("Distance 2: ");
if (distance2 >= 400 || distance2 <= 2) {
else {
Serial.print(distance2);
Serial.print(" cm");
Serial.println(" ");
ERROR:
Arduino: 1.8.3 (Windows 7), Board: "Arduino/Genuino Uno"
newping_median_b_m:38: error: array bound is not an integer constant before ']' token
C:\Users\HUA.DELLV-PC\Documents\Arduino\newping_median_b_m\newping_median_b_m.ino: In function 'void loop()':
newping_median_b_m:78: error: 'sonar1' was not declared in this scope
newping_median_b_m:86: error: 'sonar2' was not declared in this scope
Multiple libraries were found for "Adafruit_Sensor.h"
Used: C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\Adafruit_Sensor-master
Not used: C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\Adafruit_Unified_Sensor-1.0.0
exit status 1
option enabled in File -> Preferences.
