Whats wrong with this code
Hello, I get following error: exit status 1 because the code cannot be compiled for the arduino nano. Now iam asking the community, whats wrong with this code? Here is the code:
// #include “FastLED.h”
// How many leds in your strip?
#define NUM_LEDS 266
// For led chips like Neopixels, which have a data line, ground, and power, you just
// need to define DATA_PIN. For led chipsets that are SPI based (four wires - data, clock,
// ground, and power), like the LPD8806 define both DATA_PIN and CLOCK_PIN
#define DATA_PIN 3
//#define CLOCK_PIN 4
#define COLOR_ORDER GRB
// Adalight sends a “Magic Word” (defined in /etc/boblight.conf) before sending the pixel data
uint8_t prefix = {‘A’, ‘d’, ‘a’}, hi, lo, chk, i;
// Baudrate, higher rate allows faster refresh rate and more LEDs (defined in /etc/boblight.conf)
#define serialRate 500000
// Define the array of leds
CRGB leds[NUM_LEDS];
// Uncomment/edit one of the following lines for your leds arrangement.
// FastLED.addLeds<TM1803, DATA_PIN, RGB>(leds, NUM_LEDS);
// FastLED.addLeds<TM1804, DATA_PIN, RGB>(leds, NUM_LEDS);
// FastLED.addLeds<TM1809, DATA_PIN, RGB>(leds, NUM_LEDS);
// FastLED.addLeds<WS2811, DATA_PIN, RGB>(leds, NUM_LEDS);
// FastLED.addLeds<WS2812, DATA_PIN, RGB>(leds, NUM_LEDS);
FastLED.addLeds<WS2812B, DATA_PIN, COLOR_ORDER>(leds, NUM_LEDS);
// FastLED.addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS);
// FastLED.addLeds<UCS1903, DATA_PIN, RGB>(leds, NUM_LEDS);
// FastLED.addLeds<UCS1903B, DATA_PIN, RGB>(leds, NUM_LEDS);
// FastLED.addLeds<GW6205, DATA_PIN, RGB>(leds, NUM_LEDS);
// FastLED.addLeds<GW6205_400, DATA_PIN, RGB>(leds, NUM_LEDS);
// FastLED.addLeds<WS2801, RGB>(leds, NUM_LEDS);
// FastLED.addLeds<SM16716, RGB>(leds, NUM_LEDS);
// FastLED.addLeds<LPD8806, RGB>(leds, NUM_LEDS);
// FastLED.addLeds<WS2801, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);
// FastLED.addLeds<SM16716, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);
// FastLED.addLeds<LPD8806, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);
// initial RGB flash
LEDS.showColor(CRGB(255, 0, 0));
LEDS.showColor(CRGB(0, 255, 0));
LEDS.showColor(CRGB(0, 0, 255));
LEDS.showColor(CRGB(0, 0, 0));
Serial.begin(serialRate);
Serial.print(“Ada\n”); // Send “Magic Word” string to host
// wait for first byte of Magic Word
for(i = 0; i < sizeof prefix; ++i) {
waitLoop: while (!Serial.available()) ;;
// Check next byte in Magic Word
if(prefix == Serial.read()) continue;
  • // otherwise, start over*
  • i = 0;*
  • goto waitLoop;*
  • // Hi, Lo, Checksum*
  • while (!Serial.available()) ;;*
  • hi=Serial.read();*
  • lo=Serial.read();*
  • chk=Serial.read();*
  • // if checksum does not match go back to wait*
  • if (chk != (hi ^ lo ^ 0x55))*
  • i=0;*
  • goto waitLoop;*
memset(leds, 0, NUM_LEDS * sizeof(struct CRGB));
  • // read the transmission data and set LED values*
  • for (int i = 0; i < NUM_LEDS; i++) {*
  • byte r, g, b; *
  • while(!Serial.available());*
  • g = Serial.read();*
  • r = Serial.read();*
  • b = Serial.read();*
    _ leds*.r = r;_
    _ leds.g = g;
    leds.b = b;
    // shows new values*
    FastLED.show();
    }_
Please use code tags (</> button on the toolbar) when you post code or warning/error messages. The reason is that the forum software can interpret parts of your code as markup (for example, the italics in your code above), leading to confusion, wasted time, and a reduced chance for you to get help with your problem. This will also make it easier to read your code and to copy it to the IDE or editor. If your browser doesn’t show the posting toolbar then you can just manually add the code tags:
[code]``[color=blue]// your code is here[/color]``[/code]
Using code tags and other important information is explained in the How to use this forum post. Please read it.
Please always do a Tools > Auto Format on your code before posting it. This will make it easier for you to spot bugs and make it easier for us to read. If you’re using the Arduino Web Editor you will not have access to this useful tool but it’s still unacceptable to post poorly formatted code. I recommend you to use the standard IDE instead.
When you encounter an error you’ll see a button on the right side of the orange bar “Copy error messages”. Click that button. Paste the error in a message here USING CODE TAGS (</> button on the toolbar).
