As far as I can see, it doesn't give any specs about voltage and current, so you don't really know what to compare it to.
Judging by those 2 huge heatsinks, it's an older inefficient technology, whereas Pololu's are all afaik more modern more efficient devices. Pololu's equivalent of my Motomama which is a 298 and as big as a bar of soap, is the size of a US quarter.
There's not enough information on that site, you cannot tell if its any good or even if
its single-direction or an H-bridge.
At the very least you need to know what device(s) a controller uses then you can
check the datasheet (even then the supplied part could be a knock-off).
