What's wrong with this sketch?
This Arduino Voltmeter With an OLED Display from:
The serial monitor shown 'test' only as long as the input voltage on.
#include "U8glib.h"            // U8glib library for the OLED
int analogInput = A0;  //// was 0;
float vout = 0.0;
float vin = 0.0;
float R1 = 100000.0; // resistance of R1 (100K)
float R2 = 10000.0; // resistance of R2 (10K)
int value = 0;
U8GLIB_SH1106_128X64 u8g(13, 11, 10, 9, 8); // D0=13, D1=11, CS=10, DC=9, Reset=8
void draw(void)
  u8g.setFont(u8g_font_profont17r);        // select font
  u8g.drawStr(18, 12, "VOLTAGE");
  u8g.setPrintPos(33, 40);
  u8g.drawRFrame(15, 20, 100, 30, 10);     // draws frame with rounded edges
  u8g.println(vin);                        //Prints the voltage
  u8g.println("V");
  Serial.print("File   : "), Serial.println(__FILE__);
  Serial.print("Date   : "), Serial.println(__DATE__);
  pinMode(analogInput, INPUT);
  // read the value at analog input
  value = analogRead(analogInput);
  vout = (value * 5.0) / 1024.0; // see text
  vin = vout / (R2 / (R1 + R2));
  if (vin < 0.09) {
    vin = 0.0; //statement to quash undesired reading !
    Serial.print("value=");
    Serial.println(value);
    Serial.print("vin=");
    Serial.println(vin);
  u8g.firstPage();
  do
    draw();
  while ( u8g.nextPage() );
  Serial.println("test");
Serial Monitor:
value=0
vin=0.00
test
value=0
vin=0.00
test
value=0
vin=0.00
test
value=1
vin=0.00
test
value=0
vin=0.00
test
value=1
vin=0.00
test
value=0
vin=0.00
test
value=0
vin=0.00
test
value=0
vin=0.00
test
value=0
vin=0.00
test
value=0
vin=0.00
test
value=0
vin=0.00
test
value=0
vin=0.00
test
test
test
test
test
test
test
test
test
test
test
test
Thanks.
Adam
Likely a wiring error.
Paul
Well, I assume when you connect a voltage it is above 0.09V in which case value and vin will not display on the serial monitor:
  if (vin < 0.09) {
Thanks.
