#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
const int injectorpin = 9;
const int sensorPin = A0;
int duty=0 ;
// 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 psi
int value[] = {0, 0, 0, 0, 20, 20, 20, 20, 20, 25, 25, 25, 25, 25, 25, 25, 25, 25, 26, 26, 26, 27, 28, 29, 29, 29, };
//---------------------------------------------- Set PWM frequency for D5 & D6 -------------------------------
//TCCR0B = TCCR0B & B11111000 | B00000001; // set timer 0 divisor to 1 for PWM frequency of 62500.00 Hz
//TCCR0B = TCCR0B & B11111000 | B00000010; // set timer 0 divisor to 8 for PWM frequency of 7812.50 Hz
//TCCR0B = TCCR0B & B11111000 | B00000011; // set timer 0 divisor to 64 for PWM frequency of 976.56 Hz (The DEFAULT)
//TCCR0B = TCCR0B & B11111000 | B00000100; // set timer 0 divisor to 256 for PWM frequency of 244.14 Hz
TCCR0B = TCCR0B & B11111000 | B00000101; // set timer 0 divisor to 1024 for PWM frequency of 61.04 Hz
//---------------------------------------------- Set PWM frequency for D9 & D10 ------------------------------
//TCCR1B = TCCR1B & B11111000 | B00000001; // set timer 1 divisor to 1 for PWM frequency of 31372.55 Hz
//TCCR1B = TCCR1B & B11111000 | B00000010; // set timer 1 divisor to 8 for PWM frequency of 3921.16 Hz
//TCCR1B = TCCR1B & B11111000 | B00000011; // set timer 1 divisor to 64 for PWM frequency of 490.20 Hz (The DEFAULT)
TCCR1B = TCCR1B & B11111000 | B00000100; // set timer 1 divisor to 256 for PWM frequency of 122.55 Hz
//TCCR1B = TCCR1B & B11111000 | B00000101; // set timer 1 divisor to 1024 for PWM frequency of 30.64 Hz
//---------------------------------------------- Set PWM frequency for D3 & D11 ------------------------------
//TCCR2B = TCCR2B & B11111000 | B00000001; // set timer 2 divisor to 1 for PWM frequency of 31372.55 Hz
//TCCR2B = TCCR2B & B11111000 | B00000010; // set timer 2 divisor to 8 for PWM frequency of 3921.16 Hz
//TCCR2B = TCCR2B & B11111000 | B00000011; // set timer 2 divisor to 32 for PWM frequency of 980.39 Hz
TCCR2B = TCCR2B & B11111000 | B00000100; // set timer 2 divisor to 64 for PWM frequency of 490.20 Hz (The DEFAULT)
//TCCR2B = TCCR2B & B11111000 | B00000101; // set timer 2 divisor to 128 for PWM frequency of 245.10 Hz
//TCCR2B = TCCR2B & B11111000 | B00000110; // set timer 2 divisor to 256 for PWM frequency of 122.55 Hz
//TCCR2B = TCCR2B & B11111000 | B00000111; // set timer 2 divisor to 1024 for PWM frequency of 30.64 Hz
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("water/meth ");
lcd.setCursor(4, 1);
lcd.print("injection ");
delay(200);
lcd.clear();
lcd.setCursor(2, 1);
lcd.print("% Spray");
pinMode(injectorpin, OUTPUT); // output pin 6
delay(20);
int bst = analogRead(A0);
float bstinput = bst * (5.0 / 1024.0);
float bstinput2 = bstinput * 0.5376; //int bstinput = ((bst*0.004887)*0.5376); // "1023/5= 0.004887"x"analogread 0-1023"=voltage voltage*0.5376= boost in absolute bar
float bstinput3 = bstinput2-1.000; // (boostabs-outside)x"bar to psi "
float bstinput1= bstinput3*14.5038;
if(bstinput1 < 0) // setting hg to psi at -
int duty= 0;
int i = round(bstinput1); //selecting array
int duty=(value[i]);
why wont this work ? why does duty stay at zero even with bstinput1 larger than zero ?
