Wheeled Robotics Configuration
So I'm tasked with creating a wheeled robotics kit that minimizes the amount of components that are used, utilizing the Arduino Uno. I currently have two servo motors controlled using 2 ports, 2 grounds and the 5v and 3.3v ports on the board. Eventually, the robot will be powered from a 9V battery. I want to add an Ultrasonic Sensor to perform simple obstacle avoidance. Is there away the I can attach the ultrasonic sensor to the Arduino directly without using a breadboard and any other components?
So I just want to use jumper wires to go directly from the ultrasonic senor tot the Arduino board itself without adding extra components but I do not know how to set up the configuration with out the incorporation of a bread board.
mdansani:
two servo motors controlled using ... the 5v and 3.3v ports on the board.
You mustn't power a servo from the board's 5V, and surely one of them isn't 3V3 in the first place?
Plan on using AA battery packs for motors and servos. To avoid resets caused by motor overloads and electrical noise, the Arduino should be powered separately.
Alright thank you. But is there a way I can connect an ultrasonic sensor without the incorporation of a breadboard.
Wires work, especially if properly soldered. Use flexible multistranded wire, of course.
