Hi.. I have the attiny45 core files installed and compiles and upload fine.
The problem is that when I need to compile my atmega328-pu....
Its like attiny45 is using the 28 Pins "arduino_pin.h" file.. because when I delete "the arduino_pins.h" from "hardware\arduino\cores\arduino" folder. it works.
I have also copied the "pins_arduino.h" from tiny8 folder to the "Arduino\arduino-1.0.1\hardware\attiny" and the same error
When Uploading to the atmega328-PU I NEED the "hardware\arduino\cores\arduino\pins_arduino.h" file but when I Select the attiny45 controller, I NEED TO REMOVE the "pins_arduino.h" file in order to continue.
Error when Trying to compile to attiny45 controller when "pins_arduino.h" file exists:
In file included from C:\Users\Rodrigo\Desktop\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino\/Arduino.h:213,
from C:\Users\Rodrigo\Desktop\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino\/wiring_private.h:33,
from C:\Users\Rodrigo\Desktop\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino\wiring_digital.c:28:
C:\Users\Rodrigo\Desktop\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino\/pins_arduino.h:112: error: 'DDRC' undeclared here (not in a function)
C:\Users\Rodrigo\Desktop\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino\/pins_arduino.h:113: error: 'DDRD' undeclared here (not in a function)
C:\Users\Rodrigo\Desktop\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino\/pins_arduino.h:120: error: 'PORTC' undeclared here (not in a function)
C:\Users\Rodrigo\Desktop\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino\/pins_arduino.h:120: error: initializer element is not constant
C:\Users\Rodrigo\Desktop\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino\/pins_arduino.h:120: error: (near initialization for 'port_to_output_PGM[3]')
C:\Users\Rodrigo\Desktop\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino\/pins_arduino.h:121: error: 'PORTD' undeclared here (not in a function)
C:\Users\Rodrigo\Desktop\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino\/pins_arduino.h:121: error: initializer element is not constant
C:\Users\Rodrigo\Desktop\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino\/pins_arduino.h:121: error: (near initialization for 'port_to_output_PGM[4]')
C:\Users\Rodrigo\Desktop\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino\/pins_arduino.h:128: error: 'PINC' undeclared here (not in a function)
C:\Users\Rodrigo\Desktop\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino\/pins_arduino.h:128: error: initializer element is not constant
C:\Users\Rodrigo\Desktop\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino\/pins_arduino.h:128: error: (near initialization for 'port_to_input_PGM[3]')
C:\Users\Rodrigo\Desktop\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino\/pins_arduino.h:129: error: 'PIND' undeclared here (not in a function)
C:\Users\Rodrigo\Desktop\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino\/pins_arduino.h:129: error: initializer element is not constant
C:\Users\Rodrigo\Desktop\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino\/pins_arduino.h:129: error: (near initialization for 'port_to_input_PGM[4]')
When I try to compile to Atmega328-PU without the "pins_arduino.h" it returns this error:
ArduinoISP.cpp:46:26: error: pins_arduino.h: No such file or directory
ArduinoISP.cpp: In function 'void start_pmode()':
ArduinoISP:256: error: 'SS' was not declared in this scope
ArduinoISP:258: error: 'SCK' was not declared in this scope
ArduinoISP:263: error: 'MISO' was not declared in this scope
ArduinoISP:264: error: 'MOSI' was not declared in this scope
ArduinoISP.cpp: In function 'void end_pmode()':
ArduinoISP:270: error: 'MISO' was not declared in this scope
ArduinoISP:271: error: 'MOSI' was not declared in this scope
ArduinoISP:272: error: 'SCK' was not declared in this scope
ArduinoISP:273: error: 'SS' was not declared in this scope
Any Idea to get both working?
Tks a lot
