When Drawing, how to select the starting plotting position of CNC plotter
Hello everyone,
I have built a CNC machine using arduino uno board and CNC shield. And im really a newbie to Arduino programming. When I write my name on a paper using my CNC, it writes it from right to left. How can i give the command to write it from left to right?
and how do i give the command to the machine like, first draw this one, secondly draw this one?
Softwares I use - Inkscape, UGS, Processing3
Thank you
Code for Arduino - </***********************************************************************
This sketch compiles and uploads Grbl to your 328p-based Arduino!
To use:
  • First make sure you have imported Grbl source code into your Arduino
    IDE. There are details on our Github website on how to do this.
  • Select your Arduino Board and Serial Port in the Tools drop-down menu.
    NOTE: Grbl only officially supports 328p-based Arduinos, like the Uno.
    Using other boards will likely not work!
  • Then just click 'Upload'. That's it!
For advanced users:
If you'd like to see what else Grbl can do, there are some additional
options for customization and features you can enable or disable.
Navigate your file system to where the Arduino IDE has stored the Grbl
source code files, open the 'config.h' file in your favorite text
editor. Inside are dozens of feature descriptions and #defines. Simply
comment or uncomment the #defines or alter their assigned values, save
your changes, and then click 'Upload' here.
Copyright (c) 2015 Sungeun K. Jeon
Released under the MIT-license. See license.txt for details.
#include <grbl.h>
// Do not alter this file!>
You need to change the Arduino code that you forgot to post.
Sorry. Upldated again
But there still doesn't seem to be any code in your post? ... just the header of the program?
@red_car, The only code on the Arduino would be the Grbl firmware.
OP, I think that Inkscape will control the starting point, possibly by the order that the image is created. My experience with Inkscape for making images for a plotter is limited. Are you using the G code plug-in for Inlscape?
Thanks... didn't even know that was a thing.
See Servo Motor MG90S is not working. Always givea a tick tick sound when passing a command through UGS
