Hello,,,
I've been coding some program for my robot.
My robot is an aquatic droid who is controlled by a GSM mobile, and wears a GSM shield.
The GSM shield is working its serial com. at 19200 bps.
My program, reads and writes to the shield with an emulated software serial.
My emulated software serial, is a just one more implementation of the serial com. in software, without using a chip for UART.
So, I've been reading the code of Robin2, which has an implementation of a simple software serial.
The problem is not to be with the Robin2's software.
My program is working ok, even changing timings and so on on timer 0 & 2. (Oh, I've implemented that program in pure C for AVR).
I am using an ATMEGA328P, and using internal timers.
Timer 0, is for serial rx.
Timer 1, is for controlling the servo. Sending the pulse, and refreshing it every 20ms.
Timer 2, is for serial tx.
RX & TX are working okay, even sending infinite AT commands to the GSM shield, and reading the responses of OK.
When I activate the Timer1, servo is pulsing and refreshing ok. But serial com. is missing bits on rx, and maybe in tx also...
Please, can you revise my code and tell me the improvements that are need to it, for just making everything to work in a good harmony?
Thanks,
just a reader & an arduino's fan.
My name is Abel, nice to meet you.
int main (void)
// set pin of gsm rx to input_pullup
DDRD &= ~_BV(DDD3); // set pin 3 to input
PORTD |= _BV(PORTD3); // activate pull-up resistor
// set pin of gsm tx to output
DDRD |= _BV(DDD4); // set pin 4 as output
PORTD |= _BV(PORTD4); // set output to high on pin 4
// set pin of gsm pwr to output
DDRD |= _BV(DDD5);
// set pin of gsm rst to output
DDRD |= _BV(DDD6);
// set pin of motor's relay to output
DDRD |= _BV(DDD7);
// set pin of servo-direction to output
DDRB |= _BV(DDB0);
PORTB &= ~_BV(PORTB0);
// set pin of servo-dropper to output
DDRB |= _BV(DDB1);
// setup timer0
TCCR0A |= _BV(WGM01); // CTC mode
// setup timer1
TCCR1B |= _BV(WGM12) | _BV(CS10) | _BV(CS11); // CTC mode - prescaler /64 - start timer
TIMSK1 |= _BV(OCIE1A); // enable int.
OCR1A = 4999; // set to 20ms (refresh)
// setup timer2
TCCR2A |= _BV(WGM21); // CTC mode
// setup int1
EICRA |= _BV(ISC11); // falling edge
// start UART serial com.
#if defined(DEBUG) || defined(FIXMODE)
uart_init(UART_BAUD_SELECT(SERIAL_BAUDRATE, F_CPU));
#endif
// enable g.ints
SREG |= _BV(7);
dbg("\r\nHello from APV3!\r\n\r\n\r\n")
#if defined(FIXMODE)
fixmode();
#endif
EIMSK |= _BV(INT1); // enable INT1
EIFR |= _BV(INTF1); // clear int1
//gsm_pwr(); // power on GSM module
// read all the input buffer from gsm by rx serial com. emulation.
gsm_read_resp(0);
gsm_print_resp()
gsm_read_resp(0);
gsm_print_resp()
gsm_read_resp(0);
gsm_print_resp()
gsm_read_resp(0);
gsm_print_resp()
do {
gsm_send_cmd("AT");
gsm_read_resp(0);
gsm_print_resp()
} while (1);
ISR(INT1_vect) {
EIMSK &= ~_BV(INT1); // disable INT1 int.
timer0_handler = rx_bit0;
rxbyte = 0;
OCR0A = 105; // set ticks
TIMSK0 |= _BV(OCIE0A); // enable int.
TCCR0B |= _BV(CS01); // prescaler: /8 - start
ISR(TIMER0_COMPA_vect) {
OCR0A = 104; // update ticks
rxbit = PIND & _BV(PORTD3);
rxbit = rxbit >> 3;
timer0_handler();
rxbyte += rxbit;
ISR(TIMER1_COMPA_vect) {
if (servo_pulsebegan) {
PORTB &= ~_BV(PORTB0); // end pulse - set pin to LOW
servo_pulsebegan = 0;
OCR1A = 4999; // update ticks for refresh - 20ms
PORTB |= _BV(PORTB0); // begin pulse - set pin to HIGH
servo_pulsebegan = 1;
OCR1A = ( (F_CPU / 64) * (5.15 * dir + 1391.5) / 1000000UL ) - 1;//servo_ticks (dir); // update ticks for pulsing
ISR(TIMER2_COMPA_vect) {
OCR2A = 104; // update ticks
timer2_handler();
if (txbit) {
PORTD &= ~_BV(PORTD4);
I hope you have enough code upside. If you need more, please ask me.
Thanks.
