Video: https://streamable.com/18b3xv
Code:
#include <Keypad.h>
#include <Servo.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
int position = 0;
char password[5] = "1234";
char input[5];
bool canType = true;
const byte rows = 4;
const byte cols = 4;
char keys[rows][cols] = {
{ '1', '2', '3', 'A' },
{ '4', '5', '6', 'B' },
{ '7', '8', '9', 'C' },
{ '*', '0', '#', 'D' }
byte rowPins[rows] = { 9, 8, 7, 6 };
byte colPins[cols] = { 5, 4, 3, 2 };
Keypad customKeypad = Keypad(makeKeymap(keys), rowPins, colPins, rows, cols);
lcd.init();
lcd.clear();
lcd.backlight();
char key = customKeypad.getKey();
if (key && position < 4 && canType) {
lcd.print(key);
lcd.setCursor(position, 0);
input[position] = key;
Serial.println(position);
position++;
//Checking
if(position == 4){
canType = false;
lcd.clear();
position = 0;
if(strcmp(input, password) == 0){
lcd.print("CORRECT");
else{
lcd.print("WRONG");
delay(2000);
lcd.clear();
canType = true;
Thanks for using code tags.
Please produce a normal post according to the forum guidelines. A video is not sufficient.
See also FAQ - Arduino Forum for general rules on forum behaviour and etiquette.
Hello,
Welcome to the Arduino Forum.
This guide explains how to get the best out of this forum. Please read and follow the instructions below.
Being new here you might think this is having rules for the sake of rules, but that is not the case. If you don’t follow the guidelines all that happens is there is a long exchange of posts while we try to get you to tell us what we need in order to help you, which is fru…
You have not even asked a question.
gcjr
December 26, 2022, 11:44pm
3
not sure i see a problem with the code, but it is unnecessarily complicated
consider
simply process the input once 4 values are read within the code that reads the input rather than have separate flags (i.e. "canType") and tests for "position"
#include <Keypad.h>
#include <Servo.h>
LiquidCrystal_I2C lcd (0x27, 16, 2);
int position = 0;
char input[5];
Keypad customKeypad = Keypad (makeKeymap (keys), rowPins, colPins, rows, cols);
void setup () {
Serial.begin (9600);
lcd.init ();
lcd.clear ();
lcd.backlight ();
void loop () {
char key = customKeypad.getKey ();
if (key) {
input [position] = key;
lcd.setCursor (position, 0);
lcd.print (input [position]);
//Checking
if (++position == 4) {
position = 0;
lcd.clear ();
if (strcmp (input, password) == 0)
lcd.print ("CORRECT");
lcd.print ("WRONG");
delay (2000);
lcd.clear ();
system
Closed
June 24, 2023, 11:44pm
4
