When i read my time alarm it outputs not what i set it as
here is the repositry becouse the code base is big.
This all happens in the src/classes.times_manager.hpp
I set one of the alarms to 00:00 and the other to 14:39 (on line 4, timestate constructor, movetimes constructor), but when I read them with Alarm.read() in the begin method they both return 6:28.
I use an esp32s3 and platformio
Then can you create an MCVE? Oftentimes you'll find your own problem in the process.
Hmm, i have never heard of a MCVE, I'll try to create one
here is the MCVE, it still dose the same thing:
#include <TimeLib.h>
#include <TimeAlarms.h>
#include <Arduino.h>
void alarm_callback()
  Serial.println("did something");
    Alarm.delay(100);
    tmElements_t tm;
    tm.Hour=7;
    tm.Minute=34;
    int alarmID=Alarm.alarmRepeat(0, alarm_callback);
    Alarm.write(alarmID,makeTime(tm));
    breakTime(Alarm.read(alarmID),tm);
    Serial.println(tm.Hour);
    Serial.println(tm.Minute);
the serial output is:
6
28
instead of:
7
34
Is this the output always, or a sample of that single compile? Are you setting and expecting an alarm and the code is giving you a time or a length of time until the alarm?
It gave me the same output in both the mcve and the full codebase, over multiple compiles. There is a lack of documentation for these functions, so i am asuming, the library is called 'TimeAlarms' by paul stoffregen
I think tmElements_t is from TimeAlarms.h. I read that in the examples and .CPP in the libraries.
If you set the time in TimeLib, and populate all the fields in your tm struct with valid values, your code produces what you are expecting to see.
Replace
    tm.Hour=7;
    tm.Minute=34;
with
    setTime(13, 5, 0, 25, 12, 2023);
    breakTime(now(), tm);
    tm.Hour=7;
    tm.Minute=34;
and you'll get your expected output.
tanks this worked
