When I try to compile onto esp32 error 225 appears any thoughts on how to help?
Even when I try just a uploading nothing it pops up and I’m really wanting to get over this so if any of you have solutions please share
No, for you have provided no useful or actionable information.
Just declaring any variable or blink command
Post the complete error message.
Does it occur while uploading or while running.
Uploading and compiling can’t get it to run, I will get error message
[6773] Error loading Python lib '/var/folders/ns/_0gp3kl57nz7mz26fb5qz9480000gq/T/_MEIYW4eBr/libpython3.8.dylib': dlopen: dlopen(/var/folders/ns/_0gp3kl57nz7mz26fb5qz9480000gq/T/_MEIYW4eBr/libpython3.8.dylib, 10): Symbol not found: _preadv
Referenced from: /var/folders/ns/_0gp3kl57nz7mz26fb5qz9480000gq/T/_MEIYW4eBr/libpython3.8.dylib (which was built for Mac OS X 12.7)
Expected in: /usr/lib/libSystem.B.dylib
exit status 255
Compilation error: exit status 255
Looks like maybe a library is missing, but with no code auto-formatted and posted in code tags as well as verbose output also in code tags we can only guess.
Ok thanks for the information I will try that!
Are you using micropython?
Which version of the IDE?
In the IDE click on Edit, then Copy for Forum, that will copy your code.
Come back here and just do a paste.
  Button
  Turns on and off a light emitting diode(LED) connected to digital pin 13,
  when pressing a pushbutton attached to pin 2.
  The circuit:
  - LED attached from pin 13 to ground through 220 ohm resistor
  - pushbutton attached to pin 2 from +5V
  - 10K resistor attached to pin 2 from ground
  - Note: on most Arduinos there is already an LED on the board
	attached to pin 13.
  created 2005
  by DojoDave <http://www.0j0.org>
  modified 30 Aug 2011
  by Tom Igoe
  This example code is in the public domain.
  https://www.arduino.cc/en/Tutorial/BuiltInExamples/Button
// constants won't change. They're used here to set pin numbers:
// variables will change:
const int ButtonPin = 2;
const int ledPin = 9;  // LED connected to digital pin 9
int buttonState = 0;
  // initialize the LED pin as an output:
  pinMode(13, OUTPUT); // 13 changed
  // initialize the pushbutton pin as an input:
  pinMode(2, INPUT); // 2 used 2 be buttonpin
  // read the state of the pushbutton value:
  buttonState = digitalRead(2); // also used to be button pin. testing for input from pin to board. _samuel w
  // check if the pushbutton is pressed. If it is, the buttonState is HIGH:
  if (buttonState == HIGH) { // if statment started here
	for (int fadeValue = 0; fadeValue <= 255; fadeValue += 5) {
  	// sets the value (range from 0 to 255):a
  } else { // second part of if statment
  	for (int fadeValue = 255; fadeValue >= 0; fadeValue -= 25) {
  	analogWrite(ledPin, fadeValue);
  	// wait for 30 milliseconds to see the dimming effect
  	delay(30);
  } // end of statment
} // end of void loop statment
 // words by samuel_s_Walters
Oops wrong one,
 * This example turns the ESP32 into a Bluetooth LE keyboard that writes the words, presses Enter, presses a media key and then Ctrl+Alt+Delete
#include <BleKeyboard.h>
BleKeyboard bleKeyboard;
  Serial.println("Starting BLE work!");
  bleKeyboard.begin();
  if(bleKeyboard.isConnected()) {
	Serial.println("Sending 'Hello world'...");
	bleKeyboard.print("Hello world");
	Serial.println("Sending Enter key...");
	bleKeyboard.write(KEY_RETURN);
	Serial.println("Sending Play/Pause media key...");
	bleKeyboard.write(KEY_MEDIA_PLAY_PAUSE);
   // Below is an example of pressing multiple keyboard modifiers
   // which by default is commented out.
	Serial.println("Sending Ctrl+Alt+Delete...");
	bleKeyboard.press(KEY_LEFT_CTRL);
	bleKeyboard.press(KEY_LEFT_ALT);
	bleKeyboard.press(KEY_DELETE);
	delay(100);
	bleKeyboard.releaseAll();
  Serial.println("Waiting 5 seconds...");
  delay(5000);
I don’t think I have micro python being used rn how do you use it?
I’m trying to load a sketch to Arduino IDE 2.3.4 and I get this error (Compilation error: exit status 255) can someone help ?
I compiled it OK
Did you download and include the BLEkeyboard library zip file?
Let me check
Ok. I don’t have it. Just downloaded it and tried to load to Arduino and the .ino file won’t allow me to click on and finish load
Are you working with @randomhandwiredcircuit
No sir. Doing my own project to wirelessly operate my ESP32 using my ESP32 kit app on my iPhone. Just need to verify my sketch and load to ESP32 control board
Do you have the same exact problems as discussed in posts #1 through #13
