Increase in output from turning off PWM timer
My code is as follows. I couldn't figure out a reason. When the timer is turned off, the output driving the high side of the MOSFET always remains high, and this is serious.
I want the PWM outputs to stay low when the fault loop runs.
I would be very grateful if anyone could help with this.
bool fadeCompleted = false;
Serial.begin(9600); // Initialize serial port
pinMode(9, OUTPUT); // Output A
pinMode(10, OUTPUT); // Output B
pinMode(5, OUTPUT); // mainon - output pin
pinMode(6, OUTPUT); // ntcbypass - output pin
// Removed parts related to A0
// Set initially 5th, 6th, and 2nd pins to "LOW"
digitalWrite(5, LOW);
digitalWrite(6, LOW);
digitalWrite(2, LOW);
// Configure Timer1 for PWM
TCCR1A = 0; // Clear Timer registers
TCCR1B = 0;
TCNT1 = 0;
TCCR1B |= _BV(CS10); // No prescaler
ICR1 = 64; // 80 counts for PWM mode
OCR1A = 37; // Match on Pin 9
TCCR1A |= _BV(COM1A1) | _BV(COM1A0); // Set output A rising/falling edge
OCR1B = 27; // Match on Pin 10
TCCR1A |= _BV(COM1B1); // Set output B falling/rising edge
Serial.println("Loop Cycle");
int a0Value = analogRead(A0); // Read from A0 pin
int a2Value = analogRead(A2);
int a4Value = analogRead(A4);
int a5Value = analogRead(A5);
// Convert analog input values to voltage
float voltCurr = (a2Value / 1023.0) * 5.0;
float voltTemp = (a4Value / 1023.0) * 5.0;
float voltPTC = (a5Value / 1023.0) * 5.0;
float voltA0 = (a0Value / 1023.0) * 5.0;
if (voltA0 >= 2.4 && voltA0 <= 2.6 && a0Value > 800 && a0Value < 1000 &&
a2Value >= 0 && a2Value <= 410 &&
a4Value >= 255 && a4Value <= 1023 &&
a5Value >= 0 && a5Value <= 512) {
Serial.println("Vcheck Cycle");
Vcheck();
Serial.println("Fault Cycle");
Fault();
// Print other values to the serial port
Serial.print("Current Voltage: ");
Serial.print(voltCurr);
Serial.print("\tTemperature Voltage: ");
Serial.print(voltTemp);
Serial.print("\tPTC Voltage: ");
Serial.print(voltPTC);
Serial.print("\tA0 Voltage: ");
Serial.println(voltA0);
delay(1000); // Wait for 1 second
void Vcheck() {
digitalWrite(5, HIGH); // mainon high
int a3Value = analogRead(A3);
float voltDC = (a3Value / 1023.0) * 5.0;
if (a3Value >= 530 && a3Value <= 870) {
if (!fadeCompleted) {
Serial.println("PWM Cycle");
PWM();
Fault();
fadeCompleted = false; // Reset fadeCompleted flag
Serial.print("\tDC Voltage: ");
Serial.print(voltDC);
void PWM() {
digitalWrite(6, HIGH); // ntcbypass high
digitalWrite(2, HIGH); // pgood high
TCCR1B |= _BV(WGM13); // PWM mode with ICR1 Mode 10
TCCR1A |= _BV(WGM11); // Set WGM13:WGM10 to 1010
// Fade effect
for (int i = 10; i <= 42; i++) {
OCR1B = (i * ICR1) / 100;
delay(5);
fadeCompleted = true;
void Fault() {
// Reset Timer1 registers for normal operation
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
digitalWrite(5, LOW); // mainon low
digitalWrite(6, LOW); // ntcbypass low
digitalWrite(2, LOW); // pgood low
