When I use avrdude to program an ATMega328P on my PCB it says Target doesn’t answer
Context
This is my first embedded project and with a lot of help from friends etc I have designed a PCB which has an ATMega328P wired to ISP header. There is no external clock.
Problem
When I use Arduino IDE or avrdude to communicate with the 328P I get this error
Log from Arduino IDE:
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cusbasp -Pusb -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : usb
         Using Programmer              : usbasp
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : usbasp
         Description     : USBasp, http://www.fischl.de/usbasp/
avrdude: auto set sck period (because given equals null)
avrdude: error: program enable: target doesn't answer. 1
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
Some blog posts suggested using avrdude on the command line with the -B flag to slow down the speed to 1MHz to work with the AVR in default config and where as I can see this is changing the frequency the ATMega328P is still not responding.
I ran the command from log above in console, with tail of log is:
>>> avrdude -C"C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf" -vvv -patmega328p -cusbasp -Pusb -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m -B 800
avrdude: usbasp_initialize()
avrdude: usbasp_spi_set_sck_period(0.0008)
avrdude: try to set SCK period to 0.0008 s (= 1250 Hz)
avrdude: set SCK frequency to 1000 Hz
avrdude: usbasp_program_enable()
         this check.
Even when I just try to read the fuse settings it fails
>>> avrdude -vvv -p m328p -c usbasp -P usb -b 19200 -U efuse:r:-:i -U hfuse:r:-:i -U lfuse:r:-:i -B 800
         this check.
I now realize that I probably can’t program it from the Arduino IDE since that expects the ATmega328P to be on a board with an external clock. I was going to try different fuse settings but if I can’t read from the chip then I doubt that’ll make it work.
I have tested connections between the programmer and ATMega328P pins on the PCB and they seem fine.
So, what is the right avrdude command to upload the bootloader?
And then can I upload my program from Arduino IDE or do I need to use avrdude? If avrdude must be used again then how do I generate the .hex file?
Note: If these steps are clearly documented in an up to date tutorial then send me the link as I haven’t managed to find it.
Any and all help will be greatly appreciated
PS: One forum post suggested using an oscilloscope but I don’t have one. Surely there’s a simpler answer.
Do you in fact have an usbasp programmer?
Can you post a schematic of your PCB?
Yep. I first bought this one from eBay
https://www.ebay.co.uk/itm/393236747901
but then that was probably faulty as the USB wasn't being recognised so I bought this one from Amazon
