There is a protrusion on the electric motor housings. The sensor gives a signal when it sees this protrusion. I want to see the time of 1 revolution of the motor. The average motor speed is 100 rpm. I wrote the program as follows. I see an average value of 500ms. But it gives small values from time to time. I thought it was a serial communication error, but it is not a communication error.
Why do you think it gives low values?
unsigned long newTime = 0;
unsigned long cycleTime = 0;
bool risingedge1 = LOW;
pinMode (LED_D0, OUTPUT); //Motor
pinMode (LED_D1, OUTPUT);
pinMode (LEDR, OUTPUT); //Active_Input
pinMode (LED_BUILTIN, OUTPUT); //PLC_Active
pinMode (D0, OUTPUT); //Motor
pinMode (A0, INPUT); //Stop_B normally closed contact button
pinMode (A1, INPUT); //Start_B
pinMode (A5, INPUT); //Sensor
digitalWrite (LED_BUILTIN, HIGH); // If the PLC is working, the green LED will light up.
if (!digitalRead(A0)==HIGH || digitalRead(A1)==HIGH || digitalRead(A5)==HIGH) // If any of the buttons are pressed, the red LED will light up.
digitalWrite (LEDR, HIGH);
if (!digitalRead(A0)==LOW && digitalRead(A1)==LOW && digitalRead(A5)==LOW) //If the hand is removed from the button, the red LED will turn off.
digitalWrite (LEDR, LOW);
if (digitalRead(A1)==HIGH )
digitalWrite (D0, HIGH);
digitalWrite (LED_D0, HIGH);
if (!digitalRead(A0)==HIGH)
digitalWrite (D0, LOW);
digitalWrite (LED_D0, LOW);
if (digitalRead(D0)==HIGH && digitalRead(A5)==HIGH && risingedge1==LOW)
risingedge1=HIGH;
cycleTime=millis()-newTime;
Serial.println(cycleTime);
newTime=millis();
if (digitalRead(A5)==LOW && risingedge1==HIGH)
risingedge1=LOW;
serial communication output
525
583
592
598
591
592
584
584
581
575
575
574
579
577
579
591
594
61
528
590
582
583
63
515
575
