I supported my relay module with external power and I did not feed the card with computer power, when relay module is runing(when opening usually) My mouse or keyboard device closing
This situation doesn't happen all the time, once in a while
I'm sure all the links are correct, What is problem? i never understand. because..
My arduino system has no connection with the computer, it works independently.
Thank you for support
Because of the "random" nature of the issue you may want to try using a shielded cable and also ensure that the breadboard PSU has adequate current apart from voltage.
These sorts of issue may also happen if you have a large inductive load on the same mains power circuit such as a fridge, air conditioner, washing machine etc.
In which case you may need to plug in somewhere else to avoid that mains surge/spike.
