when there is no action for 5 minutes trigger an alarm
hii all ,
i have rfid scanner with wiegand output… i am getting scanned data …with no issues…
i want to trigger an alarm or execute ISR if scanner is idle for 5 mins.…i have tried but no luck …
this is my core code to scan rfid tag…any help could be appreciated…
/* Crazy People
 * By Mike Cook April 2009
 * Three RFID readers outputing 26 bit Wiegand code to pins:-
 * Reader A (Head) Pins 4 & 5
 * Reader B (Body) Pins 6 & 7
 * Reader C (Legs) Pins 8 & 9
 * Interrupt service routine gathers Wiegand pulses (zero or one) until 26 have been recieved
 * Then a sting is sent to processing
#include "pins_arduino.h"
 * an extension to the interrupt support for arduino.
 * add pin change interrupts to the external interrupts, giving a way
 * for users to have interrupts drive off of any pin.
 * Refer to avr-gcc header files, arduino source and atmega datasheet.
 * Theory: all IO pins on Atmega168 are covered by Pin Change Interrupts.
 * The PCINT corresponding to the pin must be enabled and masked, and
 * an ISR routine provided.  Since PCINTs are per port, not per pin, the ISR
 * must use some logic to actually implement a per-pin interrupt service.
/* Pin to interrupt map:
 * D0-D7 = PCINT 16-23 = PCIR2 = PD = PCIE2 = pcmsk2
 * D8-D13 = PCINT 0-5 = PCIR0 = PB = PCIE0 = pcmsk0
 * A0-A5 (D14-D19) = PCINT 8-13 = PCIR1 = PC = PCIE1 = pcmsk1
volatile uint8_t *port_to_pcmask[] = {
  &PCMSK0,
  &PCMSK1,
  &PCMSK2
typedef void (*voidFuncPtr)(void);
volatile static voidFuncPtr PCintFunc[24] = {
  NULL };
volatile static uint8_t PCintLast[3];
 * attach an interrupt to a specific pin using pin change interrupts.
 * First version only supports CHANGE mode.
 void PCattachInterrupt(uint8_t pin, void (*userFunc)(void), int mode) {
  uint8_t bit = digitalPinToBitMask(pin);
  uint8_t port = digitalPinToPort(pin);
  uint8_t slot;
  volatile uint8_t *pcmask;
  if (mode != CHANGE) {
    return;
  // map pin to PCIR register
  if (port == NOT_A_PORT) {
    return;
  else {
    port -= 2;
    pcmask = port_to_pcmask[port];
  slot = port * 8 + (pin % 8);
  PCintFunc[slot] = userFunc;
  // set the mask
  *pcmask |= bit;
  // enable the interrupt
  PCICR |= 0x01 << port;
void PCdetachInterrupt(uint8_t pin) {
    return;
  else {
    port -= 2;
  // disable the mask.
  *pcmask &= ~bit;
  // if that's the last one, disable the interrupt.
  if (*pcmask == 0) {
    PCICR &= ~(0x01 << port);
// common code for isr handler. "port" is the PCINT number.
// there isn't really a good way to back-map ports and masks to pins.
static void PCint(uint8_t port) {
  uint8_t bit;
  uint8_t curr;
  uint8_t mask;
  uint8_t pin;
  // get the pin states for the indicated port.
  curr = *portInputRegister(port+2);
  mask = curr ^ PCintLast[port];
  PCintLast[port] = curr;
  // mask is pins that have changed. screen out non pcint pins.
  if ((mask &= *port_to_pcmask[port]) == 0) {
    return;
  // mask is pcint pins that have changed.
  for (uint8_t i=0; i < 8; i++) {
    bit = 0x01 << i;
    if (bit & mask) {
      pin = port * 8 + i;
      if (PCintFunc[pin] != NULL) {
        PCintFunc[pin]();
SIGNAL(PCINT0_vect) {
  PCint(0);
SIGNAL(PCINT1_vect) {
  PCint(1);
SIGNAL(PCINT2_vect) {
  PCint(2);
// End of interrupts code and start of the reader code
volatile long reader1 = 0,reader2 = 0, reader3 = 0;
volatile int reader1Count = 0, reader2Count = 0,  reader3Count = 0;
void reader1One(void) {
  if(digitalRead(4) == LOW){
  reader1Count++;
  reader1 = reader1 << 1;
  reader1 |= 1;
void reader1Zero(void) {
  if(digitalRead(5) == LOW){
  reader1Count++;
void reader2One(void) {
  if(digitalRead(6) == LOW){
  reader2Count++;
  reader2 = reader2 << 1;
  reader2 |= 1;
void reader2Zero(void) {
  if(digitalRead(7) == LOW){
  reader2Count++;
void reader3One(void) {
  if(digitalRead(8) == LOW){
  reader3Count++;
  reader3 = reader3 << 1;
  reader3 |= 1;
void reader3Zero(void) {
  if(digitalRead(9) == LOW){
  reader3Count++;
  Serial.begin(57000);
  // Attach pin change interrupt service routines from the Wiegand RFID readers
  PCattachInterrupt(4, reader1One, CHANGE);
  PCattachInterrupt(5, reader1Zero, CHANGE);
  PCattachInterrupt(6, reader2One, CHANGE);
  PCattachInterrupt(7, reader2Zero, CHANGE);
  PCattachInterrupt(8, reader3One, CHANGE);
  PCattachInterrupt(9, reader3Zero, CHANGE);
  delay(10);
  // the interrupt in the Atmel processor mises out the first negitave pulse as the inputs are already high,
  // so this gives a pulse to each reader input line to get the interrupts working properly.
  // Then clear out the reader variables.
  // The readers are open collector sitting normally at a one so this is OK
  for(int i = 4; i<10; i++){
  pinMode(i, OUTPUT);
   digitalWrite(i, HIGH); // enable internal pull up causing a one
  digitalWrite(i, LOW); // disable internal pull up causing zero and thus an interrupt
  pinMode(i, INPUT);
  delay(10);
  // put the reader input variables to zero
  reader1 = reader2 = reader3 = 0;
  reader1Count = reader2Count =  reader3Count = 0;
  digitalWrite(13, HIGH);  // show Arduino has finished initilisation
  if(reader1Count >= 34){
//  Serial.print(" Reader 1 ");Serial.println(reader1,HEX);
  Serial.println("A");Serial.println(reader1 & 0xfffffff);
  reader1 = 0;
  reader1Count = 0;
That's some serious bare metal programming. Can't follow most of it.
Your 5-minute delay though is easy to implement. Use a variable, every time something happens it's set to the current value of millis(), and when more than 300000 ms has passed, raise the alarm.
uint32_t lastActivity;
  lastActivity = millis();
  if (millis() - lastActivity > 300000) {
    soundAlarm();
  // the rest.
By the way, that's a pretty might long ISR you have. Maybe better to have your ISR do no more than setting a boolean flag, and then have loop() check for those flags and act upon them - including the updating of lastActivity.
i also need to consider how much time have been passed since last scan of rfid.... :confused: how to check how much time has been passed since last scan?
if an rfid scan has occured
set LastScan to millis()
set a ScanFlag to high
duration = millis() - LastScan
if duration => 5 minutes
set ScanFlag to low
print duration
LastScan will change to 0 ever time a chip is scanned.
it will count all weekend until the next scan.
timing variables need to be unsigned long
not sure how you need to handle days or weeks.
akshay123:
In the exact same way as outlined in my post above.
Just add the needed flags, variables & delay time.
thank you…dave-in-nj sir…
this is my code:
/* Crazy People
 unsigned long LastScan,duration ;
  byte  ScanFlag ;
  &PCMSK0,
  &PCMSK1,
  &PCMSK2
  NULL };
  uint8_t slot;
    return;
    return;
  else {
    port -= 2;
  // set the mask
  *pcmask |= bit;
    return;
  else {
    port -= 2;
  *pcmask &= ~bit;
  if (*pcmask == 0) {
  uint8_t bit;
  uint8_t curr;
  uint8_t mask;
  uint8_t pin;
    return;
    bit = 0x01 << i;
    if (bit & mask) {
      pin = port * 8 + i;
        PCintFunc[pin]();
  PCint(0);
  PCint(1);
  PCint(2);
  reader1Count++;
  reader1 |= 1;
  reader1Count++;
  reader2Count++;
  reader2 |= 1;
  reader2Count++;
  reader3Count++;
  reader3 |= 1;
  reader3Count++;
  delay(10);
  pinMode(i, OUTPUT);
  pinMode(i, INPUT);
  delay(10);
  if(reader2Count >= 34){
    LastScan = millis();
    ScanFlag = 1;
  Serial.println("B");Serial.println(reader2 & 0xfffffff);
  reader2 = 0;
  reader2Count = 0;
duration  = millis() - LastScan;
if(duration >= (60000*5)){
        ScanFlag= 0;
 Serial.println(duration);   }
why i cant include SoftwareSerial library in below code:
/* Crazy People
  byte  ScanFlag ;
#include <SoftwareSerial.h>
  &PCMSK0,
  &PCMSK1,
  &PCMSK2
  NULL };
  uint8_t slot;
    return;
    return;
  else {
    port -= 2;
  // set the mask
  *pcmask |= bit;
    return;
  else {
    port -= 2;
  *pcmask &= ~bit;
  if (*pcmask == 0) {
  uint8_t bit;
  uint8_t curr;
  uint8_t mask;
  uint8_t pin;
    return;
    bit = 0x01 << i;
    if (bit & mask) {
      pin = port * 8 + i;
        PCintFunc[pin]();
  PCint(0);
  PCint(1);
  PCint(2);
  reader1Count++;
  reader1 |= 1;
  reader1Count++;
  reader2Count++;
  reader2 |= 1;
  reader2Count++;
  reader3Count++;
  reader3 |= 1;
  reader3Count++;
  delay(10);
  pinMode(i, OUTPUT);
  pinMode(i, INPUT);
  delay(10);
    ScanFlag = 1;
  Serial.println("B");Serial.println((reader2 & 0xfffffff)/2);
  reader2 = 0;
  reader2Count = 0;
        ScanFlag= 0;
IT SHOWING FOLLOWING ERROR:
Arduino: 1.8.4 (Windows 7), Board: "Arduino/Genuino Uno"
libraries\SoftwareSerial\SoftwareSerial.cpp.o (symbol from plugin): In function `SoftwareSerial::read()':
(.text+0x0): multiple definition of `__vector_3'
sketch\Crazy_People.ino.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `__vector_5'
(.text+0x0): multiple definition of `__vector_4'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
Apparently SoftwareSerial uses the same interrupt vectors as your code does.
wvmarle:
Cough cough
My code.
It uses the pin change interrupts and so it would seem doe the software serial. So “all” you need to do is to put another case into the pin change interrupt routine to call the software serial receiving code. It will require some hacking of the software serial library or maybe even a rewrite.
i want to connect sim 900 A6 module through software serial...is there other way to run software serial or can i use analog pins to use software serial?
You can use what ever pins you like to run software serial, but if you want to run it with my code then you have to change the library because as you found they both use the same interrupt vector.
I do not know if anyone has written a version of software serial, and there are a few versions, that do not use this vector. It is the vector that is giving you trouble not the pins.
As I said when a pin state changes in a pin that has been tagged as generating a pin change interrupt what my code does is go into a routine that sees what pin triggered it and directs it to the right place. All I can suggest is that you add to that system and go into a software serial routine, but you will have to write it yourself, or change to an Arduino with more than one serial port.
