when to initialize serial port
Hi Folks, I wrote an own library that uses HardwareSerial as a parameter. I did something like this:
class MyClass {
  HardwareSerial *m_puart;
  public:
  void println(char *);
  MyClass(HardwareSerial &uart, uint32_t baud);
MyClass::MyClass(HardwareSerial &uart, uint32_t baud) : m_puart(&uart){
  m_puart->begin(baud);
void MyClass::println(char *str) {
  m_puart->println(str);
And I've used like this:
MyClass myclass(Serial,115200);
  myclass.println("something");
  Serial.println("something else");
This does work on arduino mega but does not work on arduino nano. On nano I need to re-call a begin-like method of MyClass that does the m_puart.begin(). Please explain why. Thanks in advance! D
You must initialize it in the setup. That’s why the Serial library itself does it there. So just make a begin method in you’re library as well. So it becomes
MyClass myclass(Serial);
  myclass.begin(115200); //(or myclass.begin() but then you have to save the baudrate)
Thank you for quick reply! I see it that your way is the right way. What confuses me that my 'illegal' code worked for me on an arduino mega...
Perhaps the constructors are called in a different order. One should never rely on the order that constructors will be called in. One should write code so the order doesn't matter.
