When to use a LED driver?
Hi there,
I am switching 5 LEDs in parallel powered using a 3.7V lipo battery using a single transistor. I have seen LED driver ICs, but when should i use this? Is my current setup sufficient? I am using a lipo fuel gauge to monitor the battery.
Cheers
Jeffro_Aus:
Always.
Jeffro_Aus:
No. At the very least you should have a resistor for each LED.
Ok, if i have a resistor also, will i still need a LED driver and what type would be suitable for parallel LEDs?
Thanks
Jeffro_Aus:
No.
A LED driver is better but you can use either. The idea is to limit the current.
PS: You also need a resistor for your transistor.
Jeffro_Aus:
For five LEDs in parallel this is perfect: an6884: Search Result | eBay
You won't even need a transistor. You can switch it directly from an Arduino pin (connect to pin 7 of that chip).
Quote from: Jeffro_Aus on Today at 10:06:10 am
This is exactly what i am after. Thanks
Should each LED have a resistor? I couldn't find any good Arduino wiring diagrams.
Actually how should the AN6884 be wired also?
Jeffro_Aus:
Nope. All you need is that chip, nothing more.
Jeffro_Aus:
Connect the anodes of the LEDs to the battery, cathodes to the chip.
Use pin 7 to switch them on/off, don't connect pin 8.
A quick diagram I just made.
(nb. Don’t worry about the “+5V”, the chip works down to 3V…)
Use pin 7 to switch them on/off, don’t connect pin 8.
Please check my attached diagram. The LEDs i will use are rated at 3.2V 20mA, and the battery voltage will vary a bit as it is a lipo 3.5-4.2V.
Is this setup fine now?
Thanks
