When do we use int and when do use void when creating and defining functions? I assume that it has to do with the function itself and what it returns, so for example when the function returns numbers then it'll be defined with an integer, and when it has conditional statements, processes and returns nothing, then we use void. Is this correct?
[int ReadLightSensor(){
x = analogRead(A0);
return (x)}
void BulbControl(){
if (x>=500){
digitalRead (13, HIGH);} ]
Batool_Khader:
Is this correct?
Somehow.
Forget about the "when it has conditional statements, processes", it's only connected to the return value of the function.
The function type merely describes what the function returns (the value that the function call evaluates to).
If it does not return a value it is declared void.
The data type in front of a function name indicates which data type it returns, if any. The data type of void indicates that nothing will be returned and any other data type indicates that the function may return data of that type. Note that it may not actually return any data, although this would be regarded as bad practice.
Note too that in order to return data a function must do it explicitly. Just changing the value of a variable in a function does not cause it to be returned. If the variable is a global then it does not need to be returned in any case.
