#include <ESP8266WiFi.h>
#include <Servo.h>
#define IO13 13
const char* ssid = ""; // Enter WiFi network name here
const char* password = ""; // Enter WiFi password here
const int servoPin = 13; // Servo motor pin settings
Servo servo; // Create Servo object
WiFiServer server(80); // Create WiFiServer object
int servoPosition = 0; // Current position of the servo motor (0 degrees or 90 degrees)
delay(10);
servo. attach(servoPin); //connect to servo motor pin
// WiFi connection
Serial.println("Connecting to WiFi...");
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("WiFi connected.");
Serial.print("IP address: ");
server.begin();
WiFiClient client = server.available();
if (!client) {
return;
String request = client.readStringUntil('\r');
if (request.indexOf("/servo/on") != -1) {
// When approaching the "/servo/on" path, change the servo motor to ON state.
if (servoPosition == 0) {
servo.write(90); // Rotate servo motor to 90 degree position
servoPosition = 90;
} else if (request.indexOf("/servo/off") != -1) {
// When approaching the "/servo/off" path, change the servo motor to OFF state.
if (servoPosition == 90) {
servo.write(0); // Rotate servo motor to 0 degree position
servoPosition = 0;
// web page response
client.println("Content-Type: text/html");
client.println();
client.println("<html><body>");
client.println("<h1>Servo Control</h1>");
client.println("<p><a href='/servo/on'>Turn Servo ON</a></p>");
client.println("<p><a href='/servo/off'>Turn Servo OFF</a></p>");
client.println("</body></html>");
client.stop();
. Variables and constants in RAM (global, static), used 28556 / 80192 bytes (35%)
║ SEGMENT BYTES DESCRIPTION
╠══ DATA 1504 initialized variables
╠══ RODATA 1196 constants
╚══ BSS 25856 zeroed variables
. Instruction RAM (IRAM_ATTR, ICACHE_RAM_ATTR), used 61183 / 65536 bytes (93%)
╠══ ICACHE 32768 reserved space for flash instruction cache
╚══ IRAM 28415 code in IRAM
. Code in flash (default, ICACHE_FLASH_ATTR), used 248420 / 1048576 bytes (23%)
╚══ IROM 248420 code in flash
A programmer is required to upload
