When using Type4047mux.h library with multiple mux
Can this library be used with multiple multiplexers? If so, is it as simple as naming them each different so maybe mux, mux1 and mux3 and specifying another SIG pin respectively? The example below is from the github for explanation of the library.
 * This example demonstrates how to read analog signals.
 * It assumes there are potentiometers connected to the 16 channels of the
 * 74HC4067 mux.
 * Project: arduino-ad-mux-lib
 * Source: https://github.com/stechio/arduino-ad-mux-lib.git
 * Filename: AnalogSignalReadExample.ino
 * Version: 1.0
 * Author: Nick Lamprianidis (adaptation by Stefano Chizzolini)
#include "Type4067Mux.h"
 * Creates a Type4067Mux instance.
 * 1st-3rd arguments initialize SIG pin (analog input on Arduino PIN A0).
 * 4th-7th arguments are the Arduino PINs to which the S0-S3 pins connect.
Type4067Mux mux(A0, INPUT, ANALOG, 8, 9, 10, 11);
  // Initializes serial port.
  // Waits for serial port to connect (needed for Leonardo only).
  while (!Serial)
 * Reads the 16 channels and reports on the serial monitor the corresponding
 * value read by the A/D converter.
  int data;
  for (byte i = 0; i < 16; ++i) {
    // Reads from channel i (returns a value from 0 to 1023).
    data = mux.read(i);
    Serial.print("Potentiometer at channel ");
    Serial.print(i);
    Serial.print(" is at ");
    Serial.print((double) (data) * 100 / 1023);
    Serial.println("%%");
  delay(1500);
