Graynomad:
Gotcha, some are IN/GND/OUT some are OUT/GND/IN and there's probably other combos as well.
Rob
I've designed a matrix to handle all three combinations:
in out gnd
out gnd in
gnd in out
You just have to know which combo it is. BTW, you can plug a sensor in a column or a row so if the sensor needs to face left-right instead of up-down, you can do that too. This is perfect for making mistakes
I made a little bench power supply with a 5v 3.3v and 317 regulators on it and bolted them all down to a large heatsink from a power supply, luckily I noticed my mistake before applying power but then I had to fish through the garbage looking for isolation pads and washers
