Are you ex-static?
You have no potential so you won't get that promotion !
...R
until you take it off, then you are re-volting
You may be discharged from the forum if you start another joke like this.
LarryD:
Don't be ridiculous. He was just trying to find common ground with the rest of us.
...R
I am normally open to these conversations but, considering the current topic, I prefer to remain neutral. I will, however, relay a message.
Robin2:
That would be shocking, as I'm a bright spark.
LarryD:
You haven't the capacity to do that, and I will resist your attempts.
Henry_Best:
I will be happy to conduct your defence, but perhaps there will be a volte-face by @LarryD.
...R
Mega resistance causes any potential to slowly drain away
I seem to be getting static for giving your current status and you are amplifying this biased and often bypassed thread.
You are quite a character and not being very complementary, way too much electricity in the air.
Don't speak in code, do I have to draw you a sketch, what is the function of this anyway?
Don't distort something that's pre-programmed and please filter your responses.
Your resistance or perhaps capacity might be affected by the Henry in you, don't choke on this.
I think you can induce there is some impedance on your part to accept mutual solutions.
If you continue, you might blow your fuse, you are too polarized and you need to rectify this.
You should have realized there is a protocol to follow.
If you continue to be active in this, others might become become passive, please meter what you say and don't make this into something that is atomic.
You could goto a binary decision OR else byte off more than you can chew.
Maybe you are a CAD or maybe a collector of weird components.
Look at the clock, time for a recharge or a reset?
We are being setup() or you were looped on IPA, this is becoming crystal clear.
I have reached a cutoff point in the frequency of this is discussion.
Now let's lower the decibels a bit and reduce the energy level.
I think we are being LED down the path and the optics isn't good.
I will not flip flop, let's leave this in a state of flux.
Robin2 seems to be quite magnetic, but while this might be true OR false he is a good speaker so he could take on your case or switch to the other side and loop back until you do what you have to do, don't delay or in a blink this will continue to float, possibly in 62.5 nano seconds.
Maybe this is another X Y situation.
Those arguments are full of holes.
...R
Robin2:
Those arguments are full of holes....R
Does that mean we are going down the conventional path of the current argument?
This thread has become rather static. I think we need to induct some additional contributors who will conduct themselves in a more positive spirit.
...R
I am shocked you would say that. :o
Are you asking someone to compile more arguments or are you looking for negative feedback.
This will be etched in memory.
Let's get geared up, motor on and get stepping into this.
I base this on noise and I can read only in isolation.
"More positive"
What on earth are you basing this inverted neutral and ungrounded input.
I think you like to Excel in reflection and just want someone to cosine a loan for you.
If you think your Word battery will have me oscillating in my BOOTs, you must have something wrong in your header.
Do put a plug in it. Surely Uno better than that.
I think we OVERSHOOT the topic a BIT.
Was this EXCLUSIVE OR can noobs get SATURATED here too.
NOT that anyone was asking NOR is this AND/OR acceptable.
I am NOT in your BRACKET as you still wear BRACES, ON at night OFF in daylight.
To INCLUDE any more is NOT DEFINED in my USER agreement.
I hope it didn't DAMPEN your // COMMENTS, as this is not IMAGINARY, it is REAL TIME.
More POWER to you.
