I am making a robot that will be controlled using a ps2 controller along with an Arduino mega 2560.what I was trying to do is that i would be able to control the no of steps a stepper motor would go on the press of a button on the controller,and also turn in the opposite direction on press of another button. I made a code ,but it seems to have stuck up in a loop and it shows up in serial monitor as buttons are being pressed even when i am not touching the controller! I am posting the code can someone point out to me where have I gone wrong or any other possible place where I could've done better?
#include <PS2X_lib.h> //for v1.6
#include <L293.h> //fr the motors at base
#include <Servo.h>
#include <Stepper.h> //for Stepper motor
PS2X ps2x;
int error = 0; // for
byte type = 0; //PS2
byte vibrate = 0; //controller
const int DPIN_MOTORA_DIRECTION = 12; //Motor A Direction
const int DPIN_MOTORA_SPEED = 3; //Motor A Speed
const int DPIN_MOTORA_BRAKE = 9; //Motor A Brake
//const int APIN_MOTORA_CURRENT = 0; //Motor A Current Sensing (Not used in this program)
const int DPIN_MOTORB_DIRECTION = 13; //Motor B Direction
const int DPIN_MOTORB_SPEED = 11; //Motor B Speed
const int DPIN_MOTORB_BRAKE = 8; //Motor B Brake
//const int APIN_MOTORB_CURRENT = 1; //Motor B Current Sensing (Not used in this program)
const int DPIN_MOTOR_MODE_LED = 10; //Motor mode indicator LED
const int STEPS_PER_REVOLUTION = 48; //Steps per revolution (360/7.5 deg.)
const int MOTOR_MAX_RPM = 15; //Max RPMs for motor
const int DELAY_LENGTH = 50; //Delay in ms for each iteration ofloop
Stepper stepper(STEPS_PER_REVOLUTION, DPIN_MOTORA_DIRECTION, DPIN_MOTORB_DIRECTION); //Stepper object for motor control
byte ok = false; //ok is true if program is okay to run, false if not
byte motorMode = false; //True if motor is enabled, false otherwise
byte smallRumble; //True if small rumble motor should run
byte rumble = 0; //Vibrate speed of big rumble motor
int leftJoyXNeutralStart = 0; //Begining of neutral zone for left joystick
int leftJoyXNeutralEnd = 0; //End of neutral zone for left joystick
L293 robo(22,23,5,24,15,6); // for
int velocityrobo = 60; // basemotor motiob ,oin 5 and 6 not used
int pos = 0;
Servo myservo;
int LS1a = 32;
int LS1b = 33;
int LS2a = 34;
int LS2b = 35;
int LS3a = 36;
int LS3b = 37;
int LS4a = 38;
int LS4b = 39; // for lead screws 4 motors x 2 outputs each
Serial.begin(57600);
error = ps2x.config_gamepad(13,11,10,12, false, false);
if(error == 0){
{ Serial.println("Found Controller, configured successful");
Serial.println("Try out all the buttons, X will vibrate the controller, faster as you press harder;");
//Set pin modes
pinMode(DPIN_MOTORA_DIRECTION, OUTPUT);
pinMode(DPIN_MOTORA_SPEED, OUTPUT);
pinMode(DPIN_MOTORA_BRAKE, OUTPUT);
pinMode(DPIN_MOTORB_DIRECTION, OUTPUT);
pinMode(DPIN_MOTORB_SPEED, OUTPUT);
pinMode(DPIN_MOTORB_BRAKE, OUTPUT);
pinMode(DPIN_MOTOR_MODE_LED, OUTPUT);
//Turn motor brakes off (should be off anyways, just being sure)
digitalWrite(DPIN_MOTORA_BRAKE, LOW);
digitalWrite(DPIN_MOTORB_BRAKE, LOW);
//Setup PS2 controller
int error = ps2x.config_gamepad(7,5,4,6, true, true);
byte controllerType = ps2x.readType();
if (controllerType == 1 && error == 0)
ok = true;}}
Main program loop
ps2x.read_gamepad(false, vibrate);
if(ps2x.Button(PSB_PAD_RIGHT))
robo.forward_2W(velocityrobo,velocityrobo);
Serial.println("robot ---------------->");
if(ps2x.ButtonReleased(PSB_PAD_RIGHT))
robo.stopped_2W();
Serial.println("robot stopped");
if(ps2x.Button(PSB_PAD_LEFT))
robo.back_2W(velocityrobo,velocityrobo);
Serial.println("<------------- robot");
if(ps2x.ButtonReleased(PSB_PAD_LEFT)){
robo.stopped_2W();
// //////////////////////////////////////////////end of base motor code ////////////////////////////////////////////
if (ps2x.Analog(PSS_LY) >= 189)
digitalWrite(32,HIGH);
digitalWrite(33,LOW);
Serial.println("LY CW works");
if(ps2x.Analog(PSS_LY) <= 60)
digitalWrite(32,LOW);
digitalWrite(33,HIGH);
Serial.println("LY CCW works");
if(ps2x.Analog(PSS_LX) >= 189)
digitalWrite(34,HIGH);
digitalWrite(35,LOW);
Serial.println("LX CW works");
if(ps2x.Analog(PSS_LX) <= 60)
digitalWrite(34,LOW);
digitalWrite(35,HIGH);
Serial.println("LX CCW works");
if (ps2x.Analog(PSS_RY) >= 189)
digitalWrite(36,HIGH);
digitalWrite(37,LOW);
Serial.println("RY CW works");
if(ps2x.Analog(PSS_RY) <= 60)
digitalWrite(36,LOW);
digitalWrite(37,HIGH);
Serial.println("RY CCW works");
if (ps2x.Analog(PSS_RX) >= 189)
digitalWrite(38,HIGH);
digitalWrite(39,LOW);
Serial.println("RX CW works");
if(ps2x.Analog(PSS_RX) <= 60)
digitalWrite(38,LOW);
digitalWrite(39,HIGH);
Serial.println("RX CCW works");
//////////////////////////////////////////leadscrew program end///////////////////////////////////////////
ps2x.read_gamepad((rumble > 0), rumble);
//See if motor position should move. First, check DPADs, then left Joystick, and finally L1/R1.
//DPAD and Joystick will move motor at variable speed (if supported by controller) and L1/R1 are precision
//movement - push to move a single step in either direction.
if(motorMode && ps2x.ButtonPressed(PSB_RED))
//L1 move motor one step to left
ButtonMoveMotor(255, 5);
Serial.println("++ 5 steps");
if(motorMode && ps2x.ButtonPressed(PSB_PINK))
//R1 move motor one step to right
ButtonMoveMotor(255, -5);
Serial.println("--5 steps");
delay(DELAY_LENGTH);
void ButtonMoveMotor(int pressure, int steps)
int motorSpeed;
if (pressure > 0)
//Use pressure reading to control speed and rumble
motorSpeed = map(pressure, 0, 255, 1, MOTOR_MAX_RPM);
rumble = pressure;
Serial.println("pressure max values");
//No pressure reading, use max values
motorSpeed = MOTOR_MAX_RPM;
rumble = 255;
stepper.setSpeed(motorSpeed);
stepper.step(steps);
