Where are my datas?
When you use file.write(), it doesn't write to the card until you flush() or close(). Whenever you open a file, be sure to close it to save your data.
I guess they are in Arduino RAM until i flush or close? So i'm limited with keeping data open (i have from time to time close/flush if i don't want to loss my datas?)? Or am i completly wrong?
Yes.
The only way to ensure that data is committed to the file is to close it. The tradeoff is that closing, reopening, and relocating the insertion point is slow. Doing so will reduce the rate at which you can write to the file.
PaulS:
hmm :-/
So it would be best to collect data until RAM is nearly full, then close the file, and open a new file instead of reopening and relocating...
Depends on whether speed or no-loss-of-data is more important.
PaulS:
Speed....AND no-loss-of-data too 8)
Close() followed by open() is the wrong way to go. It take a long time to open a file and position to the end.
With SD.h flush() does exactly the same as a close() followed by open(). With SdFat use sync().
SD.h is a wrapper for SdFat so it calls the same close() function as SdFat.
Here is close():
uint8_t SdFile::close(void) {
  if (!sync())return false;
  type_ = FAT_FILE_TYPE_CLOSED;
  return true;
As you can see, close() calls sync() and marks the file closed by setting type_.
You can call flush() or sync() as often as you like but it will cost 2048 bytes of I/O to the SD. A 512 byte block will be written to update the data on the SD, a 512 byte block containing the directory entry will be read, updated and written back, then the 512 byte data block will be read back into the block buffer.
I am the author of SdFat which is the base library for the official SD.h library.
fat16lib:
I don't want to open the same file i was closing. close firstfile.txt open secondfile.txt
fat16lib:
I'm recording a measuring value every 0.025 sec ~6 hours long in csv format.
So this would be ~864000 lines.
What would you advise me? Periodically sync?
fat16lib:
I know :wink:
You will need special techniques to record a measurement every 0.025 sec. SD cards occasionally have very long write latency. The standard allows up to 200 ms and 100 ms is common.
You can check your card by running the SdFat bench example to find the maximum write latency.
Here is the result for an old blue SanDisk 2GB card with max latency of 0.139 sec:
Starting write test. Please wait up to a minute
Write 193.80 KB/sec
Maximum latency: 139360 usec, Avg Latency: 511 usec
Here is the result for a SanDisk 4GB Extreme HD video card with max latency of 0.047 sec.
Write 160.56 KB/sec
Maximum latency: 47028 usec, Avg Latency: 618 usec
The Extreme HD card is about as good as you can do and it is too slow for your measurements in a simple sketch.
I have posted several examples of fast data loggers here Google Code Archive - Long-term storage for Google Code Project Hosting..
The file fastLoggerBeta20110802.zip examples uses interrupts for measurements and have extra buffering.
The file ChibiOS20120221.zip uses a real-time OS to run separate threads for measurement and writing to the SD. These examples also use a buffer queue between threads.
