Where can I find a OECT sensor
Hi. Please help - I'm looking for an OECT sensor similar to the one in this article about measuring the sugar content in xylem - as indicated in this Arduino project. the ability to measure sugar fluctuations in plants over time is of interest to me.
Thanks, clever people
Diurnal in vivo xylem sap glucose and sucrose monitoring using implantable organic electrochemical transistor sensors - ScienceDirect
Device fabrication
For the device fabrication a polyethylene naphtalate foil (Teonex Q65HA, 125 µm, Peutz Folien
GMBH) was cut in a circular 4” substrate. The substrate was cleaned with water and acetone,
then vacuum backed for 90 s at 120°C. Metal films of 2nm titanium (Ti) and 50 nm gold (Au)
were evaporated onto the clean surface. Photolithography (Karl Suss MA/BM 6 mask aligner)
and a Shipley 1805 positive resist were used to pattern contacts, wiring, channel and gate. The
substrate was then wet etched in I2/KI solution for Au, and H2O2/NH4Cl/H2O for Ti. The
remaining resist was stripped with acetone. A PEDOT:PSS (Clevios PH1000) mixture with 5%
v/v EG (ethylene glycol) and 1% v/v GOPS (3-Glycidyloxypropyl)trimethoxysilane) and
dodecylbenzenesulfonic acid (50 µl drop per 5 ml) was spin-coated and patterned using a
Shipley 1813 positive resist, then dry etched with CF4/O2 reactive ions, in order to create
channels and gates. The remaining resist was stripped again with acetone. In the end, the
substrate was encapsulated with SU-8 2010 (MicroChem) and openings on the active areas are
defined by wet etching with developer mr-Dev 600 (Microresist Techonology). Chemicals were
used as received from Sigma-Aldrich unless stated otherwise
https://ars.els-cdn.com/content/image/1-s2.0-S2589004220311639-mmc1.pdf, page 7
That probably doesn't help, but does give the clue that these devices aren't very market-ready by the looks of it.
I quickly scanned the methods to see if they say anything about the longevity of these sensors, but it's either not there or I missed it. However, I have a feeling they don't last very long, and given how they're made, I also suspect they're not very easy to store and transport for long periods/distances, causing distribution challenges.
I'm sure if a reliable device were on the market, the authors would have at least considered it; you could always reach out to them and ask this, but I'm afraid we can already guess their answer.
Thank you so much for such a comprehensive response. i have reached out to the authors - hopeful of a response.
Thanks again
