where can I find compiler directives list?
I need to use the compiler directive Verbose can anyone tell me how and where is this documented?
In the IDE, under the File tab, Preferences->Settings-> check "show verbose output during compilation"
aarg:
This enables verbose output of the Arduino builder, not of the compiler.
If you want verbose output from the compiler, you can add the --verbose flag to the cpp.flags in platform.txt.
Pieter
Try using the “–help” option on the compiler:
> /Users/john/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-7.3.0 --help
Usage: avr-gcc-7.3.0 [options] file...
Options:
  -pass-exit-codes         Exit with highest error code from a phase.
  --help                   Display this information.
  --target-help            Display target specific command line options.
  --help={common|optimizers|params|target|warnings|[^]{joined|separate|undocumented}}[,...].
                           Display specific types of command line options.
  (Use '-v --help' to display command line options of sub-processes).
  --version                Display compiler version information.
  -dumpspecs               Display all of the built in spec strings.
  -dumpversion             Display the version of the compiler.
  -dumpmachine             Display the compiler's target processor.
  -print-search-dirs       Display the directories in the compiler's search path.
  -print-libgcc-file-name  Display the name of the compiler's companion library.
  -print-file-name=<lib>   Display the full path to library <lib>.
  -print-prog-name=<prog>  Display the full path to compiler component <prog>.
  -print-multiarch         Display the target's normalized GNU triplet, used as
                           a component in the library path.
  -print-multi-directory   Display the root directory for versions of libgcc.
  -print-multi-lib         Display the mapping between command line options and
                           multiple library search directories.
  -print-multi-os-directory Display the relative path to OS libraries.
  -print-sysroot           Display the target libraries directory.
  -print-sysroot-headers-suffix Display the sysroot suffix used to find headers.
  -Wa,<options>            Pass comma-separated <options> on to the assembler.
  -Wp,<options>            Pass comma-separated <options> on to the preprocessor.
  -Wl,<options>            Pass comma-separated <options> on to the linker.
  -Xassembler <arg>        Pass <arg> on to the assembler.
  -Xpreprocessor <arg>     Pass <arg> on to the preprocessor.
  -Xlinker <arg>           Pass <arg> on to the linker.
  -save-temps              Do not delete intermediate files.
  -save-temps=<arg>        Do not delete intermediate files.
  -no-canonical-prefixes   Do not canonicalize paths when building relative
                           prefixes to other gcc components.
  -pipe                    Use pipes rather than intermediate files.
  -time                    Time the execution of each subprocess.
  -specs=<file>            Override built-in specs with the contents of <file>.
  -std=<standard>          Assume that the input sources are for <standard>.
  --sysroot=<directory>    Use <directory> as the root directory for headers
                           and libraries.
  -B <directory>           Add <directory> to the compiler's search paths.
  -v                       Display the programs invoked by the compiler.
  -###                     Like -v but options quoted and commands not executed.
  -E                       Preprocess only; do not compile, assemble or link.
  -S                       Compile only; do not assemble or link.
  -c                       Compile and assemble, but do not link.
  -o <file>                Place the output into <file>.
  -pie                     Create a position independent executable.
  -shared                  Create a shared library.
  -x <language>            Specify the language of the following input files.
                           Permissible languages include: c c++ assembler none
                           'none' means revert to the default behavior of
                           guessing the language based on the file's extension.
Options starting with -g, -f, -m, -O, -W, or --param are automatically
 passed on to the various sub-processes invoked by avr-gcc-7.3.0.  In order to pass
 other options on to these processes the -W<letter> options must be used.
For bug reporting instructions, please see:
<https://gcc.gnu.org/bugs/>.
