Where do i set mac and ip address - Ethercard library,ENC28j60,Arduino,Webserver
Hey,
I connected Arduino Leonardo with Ethernet module ENC28j60 with SPI.
Now I have two questions to you:
  1. Where do I set MAC address - on Arduino or etherent module?
  2. Where do I set IP address - on Arduino or on ethernet module?
The following code was uploaded to Arduino, I use EtherCard Library to webserwer
// Present a "Will be back soon web page", as stand-in webserver.
// 2011-01-30 <jc@wippler.nl> http://opensource.org/licenses/mit-license.php
#include <EtherCard.h>
#define STATIC 0  // set to 1 to disable DHCP (adjust myip/gwip values below)
#if STATIC
// ethernet interface ip address
static byte myip[] = { 192,168,1,200 };
// gateway ip address
static byte gwip[] = { 192,168,1,1 };
#endif
// ethernet mac address - must be unique on your network
static byte mymac[] = { 0x74,0x69,0x69,0x2D,0x30,0x31 };
byte Ethernet::buffer[500]; // tcp/ip send and receive buffer
const char page[] PROGMEM =
"HTTP/1.0 503 Service Unavailable\r\n"
"Content-Type: text/html\r\n"
"Retry-After: 600\r\n"
"\r\n"
"<html>"
  "<head><title>"
    "Service Temporarily Unavailable"
  "</title></head>"
  "<body>"
    "<h3>This service is currently unavailable</h3>"
    "<p><em>"
      "The main server is currently off-line.
      "Please try again later."
    "</em></p>"
  "</body>"
"</html>"
void setup(){
  Serial.begin(57600);
  Serial.println("\n[backSoon]");
  if (ether.begin(sizeof Ethernet::buffer, mymac) == 0)
    Serial.println( "Failed to access Ethernet controller");
#if STATIC
  ether.staticSetup(myip, gwip);
#else
  if (!ether.dhcpSetup())
    Serial.println("DHCP failed");
#endif
  ether.printIp("IP:  ", ether.myip);
  ether.printIp("GW:  ", ether.gwip);
  ether.printIp("DNS: ", ether.dnsip);
void loop(){
  // wait for an incoming TCP packet, but ignore its contents
  if (ether.packetLoop(ether.packetReceive())) {
    memcpy_P(ether.tcpOffset(), page, sizeof page);
    ether.httpServerReply(sizeof page - 1);
You set both in your sketch, that should be obvious from reading the code.
You did not understand me. I asked if after the progrmau upload to arduino, the MAC address is set in the arduino chip or enc28j30?
YOU did not understand the answer. The ethernet device you are using can NOT have its firmware changed. The MAC address and IP address are ONLY known to the Arduino.
